Another spring question
OrangCrush
2015 Mustang GT Auto 3.55 - X pipe,Roush axleback
I have had Steeda progressive springs and Steeda non adjustable dampeners for 4 years now.
I would like to know is their anyway to improve the ride quality via minimum drop springs or different dampeners?
OrangCrush
How’s the ride with minimum drop springs?
shogun32
Northern VA
first define the deficiencies of your current setup to the best of your ability.
did you cut down your bump stops 4 years ago? also which stops are you using?
how many miles on the current setup?
OrangCrush
Any little imperfections in the road is felt. I guess after 4 years the ride is getting old. I added the Steeda non adjustable shocks and struts after I put springs in and it helped. The bump stops are the short Steeda ones. About 12k miles on setup and 15k on car. I am just looking to see is there an alternative to going back to stock.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
The Steeda min drops still have somewhat of an increased rate compared to stock — less than the Progressives when at full rate so that could help.
The dampers you have are a great choice for a regal ride — maybe they are wearing down? What size and type of tires do you run?
OrangCrush
Firestone Firehawk tires 285/35/19 front 325/30/19 rear.
shogun32
Northern VA
feeling every little thing is normally a matter of slow-speed compression damping too tight. Since you're running tweaked Koni's I would say run the FRPP Track shocks instead. Bilsteins have fairly tight slow-speed compression which may be too similar to what you have now but would be my 2nd suggestion. Ideally you want to find a M6G person in your area with different setups and see what you prefer.
