Anderson Composites GT500 Hood for GT350
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
Hey and thanks. Supports are from procharger and the pins are from Quiklatch. Call PC and tell them you need rad supports. They add a bit of space to accommodate an intercooler but I know folks running them for this reason without a PC.
In case anyone is interested, I’ll likely be selling this car. Sweet ride with zero issues. Thanks
Resurrecting for a quick question. Where did you get the mounting brackets on the core support and hood for the hood pins? And which hood pins did you use? That is the best non-OEM setup I have seen to date and would be perfect for pre 19‘ gt350s!
ChipG
Nashville TN
Chip
'20 GT350/'95 F250/'65 Fastback/'96 Cobra Project
Another option is pins from FatFab and QuikLatch QL50s.
madlag
Snake Charmer
NC
Ah, just saw the "pre-19" clause - doesn't have the GT500 hood pin accomodations.
Exactly. I’d of went that route if I could have. Using the alternate location behind factory airbox puts them in a stupid looking spot, visually. I thought this ended up looking very good.
galaxy
St Louis
'17 GT350
Funny this topic came back up. Those procharger rad supports are pretty cool, but literally just this week at SMR (Shelby Mountain Run), I saw at least two cars with the quicklatch mounted in that same location, but within the stock rad supports. So apparently it can be done. And I agree, those other locations in the fender are too far aft.
ChipG
Nashville TN
Chip
Was mine one of the ones you saw? The '19 and '20 models have the same radiator support as the GT500 and there are nice spots for the pins accordingly. The pre-'19 models don't have that so it's more difficult to find a solution that doesn't end up moving the pins way back.
galaxy
St Louis
'17 GT350
Maybe, but the ones I specifically referenced were the guys that had the pins through the stock radiator support brackets, not the whole front end piece.
