Aluminum/Carbon Fiber Driveshaft
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
The 350/R should've gotten one from the factory along with hood pins.
and an a little red "R" badge next to the GT350...
JR369
2022 GT500 Iconic
MandoGt350R
MandoGt350R
Armando
2019 GT350R
MandoGt350R
MandoGt350R
Armando
2019 GT350R
Mad, I just today I had my QA1 carbon fiber installed and response good. I did notice an increase in slight vibration. I only got up to 75 mph. Is it normal or did I miss another part that I need or installation method? Or is it just mme and the slight increase is normal?
MandoGt350R
MandoGt350R
Armando
2019 GT350R
P.s. I did have the shop install a MGW shifter which required lowering the Tranny for the install.
460Fred
Wyoming
Fred
ā€˜19 GT350 (sold)
Shouldnā€™t have any vibration from what Iā€™ve read.
MandoGt350R
MandoGt350R
Armando
2019 GT350R
Itā€™s not too much, but not as smooth as stock for sure.
matthewr87
2018 GT350
Did you check your angles? Your transmission might have moved a touch during the MGW install. A tiny angle shift can induce vibration.
MandoGt350R
MandoGt350R
Armando
2019 GT350R
The shop did, Iā€™ll have them check it. Is there a certain angle it has to be or dead center?
Epiphany
Global
I like to disassemble things.
Hey Armando, it was great speaking to you on the phone about this. Before you take a look with the installer you may want to familiarize yourself with the thread install I did...
https://www.mustang6g.com/forums/threads/qa1-gt350-cf-driveshaft.89699/
Look at the install instructions from QA1 too...
https://www.qa1.net/assets/uploads/...guides/DS_MUSTANG_9919-210_REV_04-29-2019.pdf
Basically, ensure that:
- your shifter was installed correctly with all bolts torqued to spec
- your driveshaft was installed correctly with all bolts torqued to spec and color coding matched
- the transmission crossmember bolts are torqued to spec
- the transmission to crossmember bolts are torqued to spec
Consider rephasing the driveshaft 180* if all else fails and note any changes in the level of vibration as well as reinstalling the stock driveshaft to see if any vibration increase is coming from the shifter and not the driveshaft install.
Good luck.
MandoGt350R
MandoGt350R
Armando
2019 GT350R
Good luck.
Nice talking to you too. I appreciate the advice and I will check all these items on Friday morning. Iā€™ll get back with hopefully with everything fixed. Thanks again.
Dr. JL
2016 GT350R: GR227 and GR378
The QA1 CF driveshaft is the single best and easiest improvement to the GT350R. No NVH and now no "bucking" in first gear while at parking lot speeds.
Epiphany
Global
Talked to Armando today. While I don't know all the details he did mention that his car is all good after his mechanic went over the install again.
