Air/Fuel Ratio Question
DenisN
Moscow
Mustang 2.3 2019 year
Hi everyone!
I have eco boost mustang 2019 year.
Only 14 000 km.
First I did is changed f sensor on new (revised) with CA at the and.
there were not any issues with old, did it only after recommendations ect
First 3 000 km AFR was 13.9-14.2 on XX.
But when wether is cold, AFR is from 13.8 - 14.4.
It is do not depend on heat c temperature, the same on cold and heat.
What is the reason…?
Should I bothering??
In general, motor working smooth.
Many thanks!
EFI
Masshole central
5.Br0
Many thanks!
Sounds normal, it will fluctuate a bit more when it's cold.
engineermike
La
2018 GTPP A10
@DenisN your car targets 14.08 at cruise whether hot or cold. If you want to dig any more, log your long and short term fuel trims. Less than 5% total at cruise is ideal and would indicate it’s working perfectly.
RaceRedCaliSpecial
Louisville, KY
Nathan
2021 Mustang GT California Special
What about coming to a stop light and the AFR stays at 12.4 for a minute or two before jumping back up?
junits15
MA
Justin
2019 Mustang GT
Angrey
Coral Gables
2016 GT350
The Ford tune uses several parameters to try to maintain target idle rpm, AFR, timing, TB angle, etc. And it has different tables/strategies for torque when the A/C is on and off.
It's actually quite annoying when trying to dial in a wild setup with ginormous TB, huge injectors, etc. It's like playing a game of whackamole.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I know it is 100% safe to run Stoich on modern engines, it does save fuel, but I run mine at 13.9 AFR as the base.On the old carbs I would target 13.0 at idle, cruise and decel.
