SolarFlare
Yea I run it occasionally. I’m happy how car is now. Don’t feel the need to push it.
Should rip!!One more batch of engine bay pics, because I'm in love with how it looks lol.
Tuesday: Dyno appointment to turn up the boost and timing. 950whp is my goal but I'll be happy with somewhere around 900 if not. After that, ceramic coating gets re-done!
Wednesday = Drag radials get installed.
Thanks man, this was running 80/20. Considering trying adding a little more water to the mix though.Holy crap that's a lot of boost! I think this is pretty impressive for a new engine and meth setup. Out of curiosity, were you running 100% meth, or 60/40 like before? Very cool build and impressive!
He actually only had to pull fuel out of the tune once. He said he just pulled out a little bit up top. STFT lowest point it went on the log was 0.86. Not sure what traditional negative number that correlates to though.Wow! You're fuel trims had to be maxed. How much fuel did Lund have to pull?
Pulling 14% fuel.He actually only had to pull fuel out of the tune once. He said he just pulled out a little bit up top. STFT lowest point it went on the log was 0.86. Not sure what traditional negative number that correlates to though.
I know when testing the system at idle I've seen it drop to -30. I don't think you'd want that at WOT though lol.Makes sense I suppose. My conservative setup only pulls about 8% at 9.5 psi on 91 octane shit Arizona fuel with 60/40 meth to water. Any idea what the max fuel trim possible is on these cars?
A high STFT will be safer with meth though. Since the fuel isn't actually pulled from the tune. If the meth didn't spray it wouldnt go lean as quickly.I'd personally be happier if stft was under 5%, and long term within a couple percent. But atleast it's rich and pulling instead of lean and adding. I don't think lund gets too excited about meth tuning.
Do you have a log of that last pull?
Yeah, I think with that much boost and timing 950 should be easily achievable.Good numbers but damn a lot of boost
