AFR ranges with tunes ?
whatdoyoufeedit?
Fayetteville, NC
2019 Race Red EB A10 (Formerly 2016 3X Yellow V6 M6), 1996 Mercury Cougar XR7 4.6L A4 (Future Coyote swap candidate)
So what's the verdict between unleashed and mpt ..... unleashed idle cruising was high 14s to 15.2 and mpt is pretty much like stock at 14 but on the flip side I got better 0-60 with unleashed than mpt
Idle/cruise you do not need excessive fuel as stoich is 14.7:1. 13's in idle/cruise is too much fuel. The stock tune is not optimal for performance by any means. That is why tuned vehicles get better MPG usually. Fuel is added where needed and removed where not needed.
V6junkie
Va
2015 v6 ingot silver
So the unleashed running at high 14 to low 15 is ok ?
whatdoyoufeedit?
Fayetteville, NC
As long it's idle/cruise. Not WOT. You don't need to have excessive fuel all the time. 14.7:1 Idle/Cruise is stoichiometric (atmospheric pressure). In idle/cruise you want to be as close to 14.7:1 as possible. Ford is super conservative and runs these cars overly rich from the factory (as all manufacturers do). That does not make it right for optimization, performance, or safety when mods start going on.
Artem
North Port, FL
Artem
2016 Mustang GT M/T
If you worry about 14.7 AFR during cruise/idle you can ask Torrie to leave at 13.9-14.0(stock). That's what I asked him to do on my GT flex fuel tune. He is a great tuner and will work with you to squeeze every bit of power in safely manners.
V6junkie
Va
no its not 15 all the time just idle and cruising and 12ish at wot just curious as to whats safe and not safe is all my mpg 93 is at 13.8-14.2 idle and cruising and 11.8 wot
whatdoyoufeedit?
Fayetteville, NC
Your question has been answered. 14.7:1ish is not only safe for idle/cruise it is the goal/standard. You can't argue against atmospheric pressure. If that doesn't float your boat you can always ask Torrie to adjust it to the stock settings in idle/cruise as Artem stated. I would stick with what's giving you the better 0-60s. An unsafe tune would not give you better times period, only headaches and problems. If it's netting you better times, traps, and driveability it's doing its job.
V6junkie
Va
I gotcha now I gotchaaaaa It just wasn't clicking in my head I'll do a comparison on the 2 and go from there I just didn't get what was good and not good for safety sake of the motor appreciate the help now I've learned something new :clap2:
