Advanced track question.
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
  • Thread starter
  • Banned
  • #1
I have a GTPP Premium. Even in track mode, I know there's still some traction control. I'm trying to hit the track tonight and my question is, does advanced track pull power or interfere unless you have excessive wheel spin? I've only had it light up a couple times on the street.
Gulf Coast
2018 GTPP premium
  • Thread starter
  • Banned
  • #2
And yes, I know how to turn it off.
fionic
spaghettios and cheerios
IL
15 GT PP
advancetrac will interfere if you don't disable it.
kz
West Chester, OH
Mustangs & F150
I believe it tries to detect spin and applies brakes to wheels as well.
Gulf Coast
2018 GTPP premium
  • Thread starter
  • Banned
  • #5
But it's not slowing the car down unless it detects wheel spin correct? I'll just disable it from the get go.
daltron
Rowing All Day
California
Jonathan
2016 GT PP
I keep fuse 62 in my glove box. I find TC and AdvanceTrac to be quite bothersome. AdvanceTrac will apply the outer rear brake I believe to keep you from spinning out.
kz
West Chester, OH
Mustangs & F150
I don't have a complete knowledge how it operates, I just turn it completely off.
c-rizzle
NOLA
2017 Explorer Sport
Great post from another thread.
Base S550 GT:
Default at every start-up:
- Traction Control On
- Stability Control On
Single tap: "Traction Control Off"
- Traction Control Off
Double Tap: "AdvancTrac Sport Mode"
- Traction Control Reduced
- Stability Control Reduced
Press & Hold: "AdvancTrac Off" (e.g. Track Mode)
- Stability Control Off
AdvancTrac helps to maintain control of your vehicle on slippery surfaces using Traction Control and Stability Control by applying brakes to individual wheels and reducing engine power.
Traction control helps to avoid drive wheel spin and loss of traction.
Stability control helps avoid skids and lateral slides.
On the Base Mustang, this is all completely independent of the steering setting.
None of this has anything to do with the differential (which is a Torsen, if you have a PP). I find that the Torsen nicely kicks in and allows natural, easy correction of rear wheel drift in normal driving.
From Ford literature about Selectable Drive Modes:
Normal mode delivers a balance of
comfort and responsive handling for
an engaging driving experience.
Sport+ mode provides more responsive
steering and throttle response, plus
different shift points if your Mustang is
equipped with the SelectShift® automatic
transmission. It’s great for more spirited
driving on twisty roads.
Track mode, which is for track use only, allows skilled drivers to
push the car closer to its limits on the track before AdvanceTrac®
electronic stability control intervenes. It’s perfect for weekend
track days and autocrosses because it lets you extract the
absolute maximum from the vehicle.
Snow/Wet mode comes in handy when road conditions take a
turn for the worse. It provides confident handling by retaining
a connected-to-the-road feel without sacrificing any of the
inherent composure of your new Mustang.
