Acronym Sticky
TN GT
Middle Tennessee
James
'19 GT Premium PP MT82
How about a sticky for all the acronyms used on this site?
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Any in particular you're having trouble with?
TN GT
TN GT
Middle Tennessee
James
My Google Kung Fu is strong so I will manage :). I may add a bunch here anyways. One that stumped me until I finally looked it up was "DA" Density Altitude.
Grimace427
NoVA
2011 Mustang 5.0
I'll just toss a few out off the top of my head, I'll probably remember a hundred more after I post this haha:
  • LCA - Lower Control Arm
  • TOB - Throw out bearing
  • IRS - Independent Rear Suspension
  • VCT - Variable Cam Timing
  • DA - Density Altitude
  • MAF - Mass Airflow Sensor
  • MAP - Manifold Absolute(Air) Pressure.....some manufacturers use those terms interchangeably)
  • PSI - Pounds per Square Inch(atmosphere is approx 14.7psi)
  • kPa - Kilopascals(pressure measurement, atmosphere is approx 101kPa)
  • RPM - Revolutions Per Minute
  • ECU - Engine(Electrical) Control Unit
  • PCM - Powertrain Control Module
  • SRS - Supplemental Restraints System(airbags)
Urban Dictionary acronyms:
  • RTFM - Read the *ucking Manual
Tank
9/11 - Never Forget
Above the Notches
G0853
I'll play along:
YMMV= Your Mileage May Vary - meaning you may get different results
WTF= What the Fuck - self explanatory
SBO= Shit'll Buff Out- just made this one up. It's usually spelled out and used sarcastically.
IBTL= In Before the Lock - not so much here but in other forums, people behaving badly can cause threads to become locked by the Mods...
FPC=Flat Plane Crank
