Accelerate after linelock
mtoo22
Morgantown, WV
2018 Whipple GT
Has anyone noticed after doing a burnout with linelock that the car doesn't want to accelerate? It will sit there for 3-5 seconds even with the pedal pressed and not move. 2018 GT Base
smann
Toronto
2016 GT PP
Press OK while line lock is engaged and the tires are spinning, it'll then let off the front brakes and start moving while back tires are spinning.
You then can make a smokeshow
Edit: rolling smokeshow*
Houston Kid
Houston, TX
Good to know. Mine did that yesterday. I've only used it twice. I could not yesterday until I put it in N then back in S.
Jay-rod427
Kansas
2016 GT C/S
If you let the timer run out it gets pissed. Cancel it just before then. But if you use up all 15 seconds you are just wanting to replace your tires immediately anyway.
