A Day or Two and Boom
Tristar
Nevada
2015 GT
My 1st Mod, upgrading my 2015 GT from 18" Ok wheels and tires to
20" Wheels and tires I like after tons of reading and deciphering,
Question is, Should I go with 20x8.5 all around or 20x8.5 Front and 20x10 Rear. Tires will be 255-35-20, I think they will work on both wheels, but will they actually look any different or be any better that way?
Or does the 20x10 need a bigger tire.
My GT is the Base model so I think fitment is good whichever way I go.
Any input would be very helpful.
Thanks, Chris
ero 5.0
Bay Area, CA
Eric
2015 mustang gt 5.0
on the 20x10 you should at least go with 275's
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Front 255 or 275 with the 20x8.5
Rear 275,285,295, or 305 on 20x10
Tristar
Tristar
Nevada
2015 GT
Bad Info ?
Someone locally is telling me that doing 275 in the rear and 255 in the front will wear the front tires out sooner, does that make any sense to anyone ?
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
No.
dwaleke
Jeep
Unless you plan on doing 295+ tires in the rear I'd go square 275s all around.
20x9.5 275 or 20x10 285
You will probably save some cash with 20x9.5 and 275 tires. 275 is common size and prices are low in comparison to 285/295+.
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
you wont be able to rotate them.
Blk2015GT
2015 GT
I disagree they wont wear faster as staggered, but only in the sense that you cannot rotate them. With staggered you can only rotate side to side, but not front to back. How much faster, probably minimal in the scheme of things. But obviously your rears where they power is coming from will wear a lot faster than the fronts not matter what size tire. Front to back rotation is important on a high hp car if you don't want to replace tires every 10,000 miles in the rear.
I've always hated staggered setups since my S197. This time the S550 can handle a 275 tire up front and rear so I went 275s square on 20x10 wheels. Now I can rotate front to back (although not side to side because I unknowingly got directional tires, but the front to back is the biggest wear on the tire overall since only one end is driven by the drivetrain)
I do agree OP, I thought I would last on the stock 18s a while, but the 20s just looks so much better on the car and fill the wheel well much nicer. Totally better look.
Tristar
Tristar
Nevada
2015 GT
Fill her up ?
Do you think if I stick with my original plan, it will look good too, really what I can afford and have all items located for locally and AM
255-35-20 Tires on 20x8.5 FR500 Wheels, on a 2015 GT
Will these fill the wheelwells better and will they look as fat if not fatter than what came stock ??
Wish I could find a pic of a 2015 GT Ruby Red with these on it, hahahah
Tristar
Tristar
Nevada
2015 GT
Got wheels issue maybe?
Anyone know the answer to this
I got the American Muscle FR500 20x8.5, they showed up today, look great and fantastic deal thanks to our Rep on here. Tires will be in Monday, Install Day :-). Then out of the blue on another forum a member tells me I cant use my original lug nuts, tell me this isn't so. I did not get new lug nuts for two reason, thought I could use the old, save money, and AM is out of the ones you can add if you want too. Also on the AM site it does not mention special lug nuts. AM I missing something or am I ok and stock will work?
Thanks for any info. Chris
assclown
Warchief
GTA - Canada
Dee
2015 GT Vert
Usually for aftermarket wheels, the diameter in the new wheels is smaller than the stock lugs. It's best to check the description of the item, or PM one of the AM folks on the board who can help steer you.
In my quest for wheels, none but the stock wheels were compatible with the stock lugs. They all call for smaller diameter ends.
Tristar
Tristar
Nevada
2015 GT
Quick
Thanks for the info, this is going to cause me more issues if correct, not much time left to get a set of correct lugs here, there is no info with the wheels at all, I wrote AM, no answer so far.
Oh well
Thanks, Chris
Old 5 Oh
Wilder, ID
David
2015 GT Premium AT
Not even a little bit.
Are you sure they aren't telling you that you can't rotate them since they are different-sized, and that means they will wear out sooner? Not necessarily true anyway.
Tristar
Tristar
Nevada
2015 GT
He is old school
He actually sold tires and said this as well as the rotating thing.
I already ordered everything now, now I got the possible lug nut issue?
