94 octane in my GT?
Emt1581
PA
2017 Magnetic Mustang GT w/PP & TurboBooster Seat
Since it's factory tuned for 87, can I run 94 in my 2017 GT or do I need a tune of some sort? Also, if I do go to 94, what are the benefits?
Thanks!
Schwerin
Home
2019 Mustang
Nope 94 will run just fine. I miss when Sunoco had 93 in my area.
No real benefit. I believe the advertised HP numbers are with 91+, so really it will be just that you're finally getting the most HP your car can make in stock form. You MAY also get better MPG since youre getting a better burn.
EFI
Masshole central
5.Br0
Yes you can run it, and you might gain a hp or two over running 93 as the PCM will compensate slightly for the higher octane.
And technically the car is tuned for 91, but can run on 87.
Emt1581
PA
I've only ever ran 91 in it but ok good to know! Thanks
