5.0 Rebuild Question
GerardoP
Phoenix AZ
Gerardo
2015 Mustang GT
I have a Gen 2 5.0 with high miles, i regularly do maintenance but i do want to go boost in the near future but im scared of something breaking right away. Is there a specific rebuild kit that i can get first?
robvas
MI
2011 GT
Gen 2 engine isn't exactly weak. If you want, call up your favorite Mustang shop for a set of forged pistons/rods, and then you want to get your heads rebuilt, new timing set, bolts, gaskets, oil pump gears, block will likely need cleaned up....$$$$
GerardoP
GerardoP
Phoenix AZ
Gerardo
2015 Mustang GT
so would a bottom end rebuild be more of the priority?
robvas
MI
2011 GT
How much boost/hp do you plan on running? If it's under 14psi/800hp I would just run the stock engine.
Also, when you say your engine has high miles what do you mean 80k? 120k? 180k?
GerardoP
GerardoP
Phoenix AZ
Gerardo
2015 Mustang GT
I want to be running around 8-9 psi with a 120mm pulley, the car has 153k.
