mustangtaxman
subd
Just posting other options they may come available.We are currently working on these pads. We are hoping to have them ready for this summer.
I know I've read about not pushing fluid back into the ABS HCU a number of times in 'Brake & Front End' magazine. It's an automotive repair industry periodical.I'm not sure how much truth there is to this statement but, I've "heard" that pushing the fluid back towards the master cylinder too quickly can damage the anti-lock brake system. I usually loosen the bleed screw just as the other post suggested.
That is correct Norm, good advice.I know I've read about not pushing fluid back into the ABS HCU a number of times in 'Brake & Front End' magazine. It's an automotive repair industry periodical.
Pushing dirty fluid into the ABS unit is bad no matter how slowly it happens.
Norm
Wouldn't that mean you are low on brake fluid after this procedure? So basically you should be adding brake fluid and draining brake fluid when you change your pads? [MENTION=6743]Norm Peterson[/MENTION]When you compress the pistons back into their bores, you should be cracking the bleed screw and running a hose off to a container. This goes for the rear brakes, too.
Don't be pushing the dirtiest fluid in the system back up into the ABS hydraulic control unit.
Norm
