FordTechOne
How are you going to use a C-Clamp on fixed calipers.....:headbonk:use a C clamp to compress pistons
just like thisHow are you going to use a C-Clamp on fixed calipers.....:headbonk:
And that, everyone, is how you damage an aluminum caliper body :doh:just like this
Brakes are just like tires; the mileage that they last depends entirely on how the car is driven.I am at 20k miles and my Brembo/PP brakes are squealing and making an awful resonating noise when under 10 MPH as well. I would hope that the brakes last longer than 20k miles... My back tires only lasted 19k but I get that...
How do you like the 1521's so far vs. GTPP pads? How is initial bite? How about hard braking and repeated hard braking? A lot less dust?I changed my front pads out to Carbotech 1521's, mainly for less dust. No special tools needed. You don't need to remove the caliper. Just change one pad at a time, so you don't have 6 pistons to compress back in. The pads themselves take a bit of coercing to get out, but you can do it with just your fingers and/or a small screwdriver to push them out. Reinstalling the clips and pins is also a small lesson in patience if you've never done it.
Damn, 19k out of the back tires? I got 10k and I never did a burn out.I am at 20k miles and my Brembo/PP brakes are squealing and making an awful resonating noise when under 10 MPH as well. I would hope that the brakes last longer than 20k miles... My back tires only lasted 19k but I get that...
I would say approximately 50% less dust. I haven't autoX'd them yet, but they are very comparable on the street to the stock PP pads. Also, less initial bite which some may like as the brakes are now less "touchy".How do you like the 1521's so far vs. GTPP pads? How is initial bite? How about hard braking and repeated hard braking? A lot less dust?
Thanks for the info. Trying to decide what pads to go with:frusty:I would say approximately 50% less dust. I haven't autoX'd them yet, but they are very comparable on the street to the stock PP pads. Also, less initial bite which some may like as the brakes are now less "touchy".
I bought a brake tool kit I think from Harbor Freight some years ago, but Autozone rents then for FREE with a refundable deposit.And that, everyone, is how you damage an aluminum caliper body :doh:
That's called being a HACK. And when you only push in the calipers one side at a time, the other side will push out, rendering that method useless.
The only proper way to retract pistons in a fixed caliper is with the proper piston retraction tool. Don't spread bad information that will cause people to damage their expensive Brembo calipers.
Like this one?And that, everyone, is how you damage an aluminum caliper body :doh:
Where did you get these pads at? I'm definitely interested in less brake dust.I changed my front pads out to Carbotech 1521's, mainly for less dust.
