5.0 Engine Crankshaft Damper: Same as GT350?
Status
Not open for further replies.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Anyone know if the damper on the 5.0 engines is the same that Ford uses on the GT350 engine?
BMR Tech
BMR Tech
Tampa, FL
Dion
Also, what is the hard limiter set to on the GT350?
MCJUNKMAN
SE Michigan
2015 Mustang GT PP
I believe fuel cut is set to 8250 under ideal conditions ie all temperatures are safe. The crankshaft damper is quite a bit different due to the different crank and rotating assembly of the 5.2.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Yes the flat plane crank damper should be different to help quill the excessive vibrations that come with flat plane crankshafts. Ford did a great job with it!
Status
