TUNES affect manual same as AT ?
wimbrow
auckland NZ
tom
2016 GT fastback black
hi members. does a tune affect a MT as much as an AT? thanks
franklin9150
San Antonio, Tx
2015 Magnetic GT Premium PP
As far as I know, a tune does nothing to the transmission itself on a manual car. On an auto, it adjusts the shift points and such, but nothing on a manual.
Laztug
Wanna run dyno slips bro?
COTUS
Calling out OKC #1 spot after axle back install.
Yes, if done properly you will feel a major difference in how the car runs. Shift firmness, shift points, tq management etc. can all be controlled with a tune.
TheFaulk
Greenville, South Carolina
None
A tune doesn't effect the manual trans. It doesn't run off of an ECU you still shift it at the desired rpm. The car may reach said point faster but it won't effect how smooth the trans shifts.
beefcake
Bethel
2018 Ford Mustang
what is it your looking for out of a tune
beammeup
Australia
2016 Mustang
Could someone explain what the clutch protection feature is on a manual tune please?
Need4Speed15
Parkland, FL
2015 Magnetic GT Auto
Livernois Motorsports
Dearborn Heights, Michigan
www.livernoismotorsports.com
S550 HQ
2016 Mustang GT (TVS 2650) (6R80)
To answer your question, YES.
Of course there are certain parameters that are changed in an auto trans cal that do not exist in a manual cal.
There are several things that are changed in the manual trans cal other than just the rev limiter. Which is what people assume is the only thing that can be changed. The only major thing that gets changed in an auto that doesn't in the MT cal are shift points. Obviously, you chose the shifts (for the Most part) in a MT car.
Joe 5.0
Bermuda Triangle
2015 Mustang GT/PP
In terms of warranty, if something breaks in the transmission, is the transmission still covered on an MT car with a tune?
GigaHz
Pa
2015 Mustang 2012 Taurus SHO
Only your dealer can answer that.
