325 Tire?
danno1
CT
2019 GT PP2
Someone on YouTube installed a 325 wide rear tire on a 2019 PP 2 wheel. Would that work?
Mad Horse
Boston
Paul
2019 Mustang GT PP2, 2018 Explorer Sport, 2013 Fusion
I had 325s on a set of SVE SP2 wheels and I didn't like how much they poked. They never rubbed however.
danno1
danno1
CT
2019 GT PP2
The YouTube said it now matches the width outside the fender as the front PP2 wheel
danno1
danno1
CT
2019 GT PP2
So I guess it's possible on the pp2 with the offset?
danno1
danno1
CT
2019 GT PP2
How much wider is a 325 over a 305?
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
10mm on the inside, 10mm on the outside. 10mm is about 0.4”. Also realize not all 325’s will measure identical. With the 19x11 +50, the 325’s stick out about 1/3” farther than the stock 305’s on the 19x11 +48.
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
Also realize a 325/30/19 is about 1/2” taller than a 305/30/19, so it will also effect your gearing a little bit. The 3.73’s with the 305/30/19 are about like a 3.93/4 rear gear when compared to the 275/40/19 on a PP1 with 3.73. I can trap about 114-115 in the 1/4 mile in 3rd gear with the 325/30/19’s.
danno1
danno1
CT
2019 GT PP2
Would never expect that tire being taller half inch. So, if that same tire were a 325/35/19 would that be same height?
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
No.
The '30' and '35' are not hard sidewall height numbers. They are sidewall heights as a percentage of tire section width.
To the nearest 0.1"
305/30-19 is about 26.2" tall, each sidewall would be 305 x 0.30 ÷ 25.4 = 3.6"
325/30-19 is about 26.7" tall, each sidewall would be 325 x 0.30 ÷ 25.4 = 3.8"
325/35-19 is almost 28" tall, each sidewall would be 325 x 0.35 ÷ 25.4 = 4.5"
Norm
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
A proper wheel fitment for a 325 is more like an 11.5-12" wide wheel. The "will it fit" ? Sure, you can mount a 325 on an 11", and for a drag tire, it may not be a huge deal, but you're introducing a bit of a compromise in overall handling (and may not even be increasing the contact patch that much).
FWIW, I run a 305/35 on my rear 20x11 wheels (ET50 offset).
danno1
danno1
CT
2019 GT PP2
Got it. Thanks guys. Very interesting.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
I run a 325/30R19 on a 19x10 wheel. Saves on curb rash. Clears everything. Fender gap sucks.. but I ain't lowering it.
danno1
danno1
CT
2019 GT PP2
Would you have any pics on different angles?
