285/35/19 Question
ghostman
American Outback
2015 GT
Hello,
I purchased some LMR GT7s in 19X10 for all for corners. I have been running the stock 255/40 Pirellis for a while but am ready to purchase the right size tires for these wheels. I have decided on the 285/35s because the diameter is within .1 inch of the stock diameter.
When I put the stock tires on the new wheels the clearance up front was pretty tight. I just want to confirm with the smart folks here that the 285s are going to fit properly without rubbing or the need for spacers. I am afraid the installer is going to balk and I want some proof to back me up when I tell them they will fit.
I am trying to decide between the Conti ExtremeContact DWS06 and the Michelin Pilot Sport A/S 3+.
Thanks in advance.
sloppymax
Clover, SC
2015 Mustang GT
I run 285/35 with Steeda non adjustable struts with 19X10 LMR GT350 wheels and there is clearance. There is not much but I have no rubbing, inside or otherwise on BMR SP089s up front.
ghostman
American Outback
2015 GT
Just had 285/35/19 Continental ExtremeContact DWS06s installed. They look and fit great! Thanks again for the help.
2017OxfordStang
PA
17 GT
Hello, How much clearance do you have? I just installed this same setup and I'm concerned about the very tight clearance, somewhere between 2 and 3 mm. I'm doing a track event and I'm concerned that as the tire heats it may rub, is that a reasonable concern?
Triton54
Delano Mn.
Greg
18 GT A-10 (mine) 17 GT pp, 6spd (wifes)
I Just installed this set up last week, (285/35/19) I went with Ace Alloy's AFFO2 19x10's I am NOT lowered, and have plenty of clearance all around front and back. ( Base GT) +35 offsets
Dave TBG
Patiently waiting...
New Jersey
'19 EB 201A, '86 Porsche 944
pics?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
2-3mm is tight but you should be fine on track. Mark the strut to check it afterwards if you’re curious.
Grintch
Hunstville
2015 GT PP
What offset are the LMR GT7s? I have to run 3-5mm spacers up front with wider than average 285s on 19x10 +40 wheels, so +40 is iffy, but +35 should be fine.
All 285/35R19 are not exactly the same size, plus camber, ride height etc. will also impact clearance.
Dave TBG
New Jersey
Dave TBG
New Jersey
Pics?
