285/35/19 // 305/30/19
heardme
CA
How would this setup look? It was recommended to me.
They would go on a 19x10 19x11 setup.
15GTPP
El Paso
2019 GT
Have this exact setup. I wish I would have gone with a 35 profile in the back. The 30 looks too small.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
I have a set of nitto invos 285/35/19 on 19x10 wheels. It looks awesome. After my n/a build is done i will be adding 305/35/19 nt05r dr's to those same rims... About an inch wider and taller..should look ever more awesome!!!
scott_0
Oxford, Pennsylvania
the rear tire would be .7" shorter than the front if you do those sizes, goofy looking imo. a 305/35/19 is much better option, it would be .5" taller than the front tire
use this tire calculator:
https://tiresize.com/calculator/
heardme
CA
Thank you guys, I thought it might be off after I did a little math.
Soonertim4
Spring, Tx
Timothy
2021 twister orange gt performance pack
Do the 305/35/19
heardme
CA
So it seems like the only brand that makes 305/35/19 are Michelin Pilot Sports which are about $600 more for the set than I had originally chose (Hankook Ventus V12 Evo2).
Should I go with:
285/30/19 305/30/19?
Soonertim4
Spring, Tx
Timothy
Ummmmmm
Nitto Ntr05
Nitto ntr05r
Nitto nt555 g2
M/t et street s/s
Couple pirelli's
What are your goals with said tire?
heardme
CA
I just want them to look good with my wheels (Forgestar CF5V)
Do you think lower profile tires might match better?
EDIT: So I think the tire sizes are only available on the Michelin Pilot Sports of the tires the vendor carries. I'm trying to see if he can source the Nitto nt555 G2. Thanks for the recommendations Sooner.
If they can't, how do you think the 285/30/19 and 305/30/19 setup would look?
Soonertim4
Spring, Tx
Timothy
In the 19's youll be a lot happier with a 305/35 tire mainly from the height. If you have an 11" wheel you can go 325/30 but it will be shorter
You can almost get any tire to look good with those wheels
If you want only look with awesome tread pattern go with any stated above.
The one thing ive learned. Is you cant have the best of both worlds
heardme
CA
I'm guessing that the vendor is limited to Michelin Pilot Sports, Hankook Ventus V12 Evo2, and Continental Extreme Contact DWS 06.
I don't think 325/30/19's are available in the Hankooks or Continentals. I guess I'll follow up with them to see if they can source other tires. I already prepaid for a bunch of stuff there including the tires because I ordered the Forgestars. I just noticed that the tire setup was off on the invoice. 285/35/19 and 305/30/19.
Soonertim4
Spring, Tx
Timothy
What do you want out of your tires?
heardme
CA
I guess the most important thing is looks for me.
Soonertim4
Spring, Tx
Timothy
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
285/305 will work fine on the car, and you can do a 325 on the rear no issues.
