259° CHT
18GTmustang
Houston tx
Eduardo Perez
2018 ford mustang GT
Today i had my car on idle for about 1 hr.
cylinder head temp got to 259 and the guuge was like 3/4s to the hot side.
coolant temperature said normal. I read on another thread to check for air on the system. Any tips on what else to check for?
Btw when running cht are on the low 200s .
the cooling system was worked on due to a repair so maybe it does have air on the system.
robwlf
phila
rob
17 lightning blue pp LFP 670
yeah id get it checked for air it sounds like it to me ..
18GTmustang
18GTmustang
Houston tx
Eduardo Perez
ill will be installing the 170° thermostat this weekend since i finally going to get 2 days off..
and going to try to fix this issue.. another thing i notice is engine bay heat is way worse with the headers than with stock manifolds
robwlf
phila
rob
o yeah with headers you'll always have more heat in the bay with headers .. yeah do the 170 t stat.. after that burp the system.. and make sure to have the heat on full blast when your burping it .. helps get the air out of the heater core
burping it is pretty much leaving the cap off the rad... when cold of course, let it idle with the heat on full blast when it gets up to temp.... then keep squeezing the upper and lower rad hose . lower first then upper if you see bubbles then its getting air out ... old school but it still works
SheepDog
Colorado
Dax
Make sure your cooling fan is working
18GTmustang
18GTmustang
Houston tx
Eduardo Perez
thank you so much for the help i sure will give it a try
robwlf
phila
rob
np at all .. ive been doing it like that for a long time and it always works
