20x10 wheel
I Bleed Ford Blue
North East OHIO
will a 20x10 wheel with a 35mm offset work on the front GT350 brakes? Will it poke too much or sit flush?
I want to put the GT 350 brake kit on and run a 20x10 Front with a 285/30 or a 295/30 and a 20x11 rear with a 315/30
GAGT350
Temple, GA
Anthony
2019 GT350, 1983 S10 Sport Pickup
sublime1996525
SL,UT
2017 Race Red GT350
I’m running a 19x11 square setup with a 25mm spacer. I would assume 20x10 would easily fit with the 25mm spacer. Or depending on the offset, no spacer at all.
I Bleed Ford Blue
I Bleed Ford Blue
North East OHIO
the wheels I'm looking at have a 35 mm offset
JAJ
Vancouver BC
2016 GT350 Track Pack
Maybe. The 35mm offset will put the inside flange of the rim at about the same distance to the strut as the 19x10.5 30mm offset OEM GT350 rims. The outer flange will be 1/2 inch further in, so there shouldn't be a problem with the fender.
Clearing the brakes is the tricky bit. The GT350 front calipers are huge and rims that ought to fit might not have enough relief behind the spokes, causing them to rub against the face of the caliper.
