Check the manual, I don’t recall. If I remember correctly there is a master volume control which requires the knob being plugged into it.
Are you using the remote turn on from the PAC?Plugged in the remote base and no change. Software is at most current. I made a jumper from constant 12v to the remote and everything works (sounds frigging amazing actually). I may just need to run a remote to a switched source...any suggestions on that?
I really wish thereThere has to be an easier way.. my brain exploded then started on fire reading this lol.. wtf!!
I really wish there was, when I started my project all I wanted was a simple upgrade. Those days are over, thank god for the Amp Pro and the pre-made harnessesThere has to be an easier way.. my brain exploded then started on fire reading this lol.. wtf!!
So if a guy has the premium B&O with the amp can you swap speakers and gain a little? Or do you have to go all out with aftermarket amps etc.. for some reason my rear deck speakers in my car are trash. Almost no sound coming out. I wanna swap to a different speaker with just thoseI really wish there
You likely to notice very little improvement. Trash in equals trash out. And the rear deck speakers are choked off by the rear package tray. They are also underpowered.So if a guy has the premium B&O with the amp can you swap speakers and gain a little? Or do you have to go all out with aftermarket amps etc.. for some reason my rear deck speakers in my car are trash. Almost no sound coming out. I wanna swap to a different speaker with just those
So honestly, if you wanted noticeable improvement with the least amount of effort, I know it sounds counter intuitive, but the stock speakers are not the main problem. If you put in the Amp-Pro unit and a better amp and left the stock speakers it might be enough for you personallySo if a guy has the premium B&O with the amp can you swap speakers and gain a little? Or do you have to go all out with aftermarket amps etc.. for some reason my rear deck speakers in my car are trash. Almost no sound coming out. I wanna swap to a different speaker with just those
Interesting… I’ll look into it this spring when the car comes back out. ThanksSo honestly, if you wanted noticeable improvement with the least amount of effort, I know it sounds counter intuitive, but the stock speakers are not the main problem. If you put in the Amp-Pro unit and a better amp and left the stock speakers it might be enough for you personally
Yes, look above your hood release handle.... so does the 2021 - 9 speaker system have an amp??
(no subwoofer in trunk).
Saw it... thank you!Yes, look above your hood release handle.
