lol yeah that rear screw for the back speakers is a bitch! I ended up buying a Dewalt right angle driver which was still just a little too tall to get back there.All speakers installed...every single adapter plate needed to be modified to fit. The 3.5s have a different harness, so those had to be cut and wired direct. Tested continuity from the speaker wire to the PAC harness...works great! I did use the harness rear speaker wires for the tweeters, which were also a pain in the ass to mount to the A-pillers. Essentially using the harness wire to get from the kickpanel to the trunk.
For the rear, I decided to flush mount the tweeters in the rear deck mat vs. using the b-pillers. This is mainly due to the airbag worry and ease of modifying the carpet mat cardboard vs. the plastic piller. Oh BTW, that rear bolt for the rear deck 6.5 was fun....
Next up is the amp rack, connecting everything and tuning. Still thinking of the layout...this is what I have so far. Still need to carpet it up.
Any suggestions?
View attachment 798198 View attachment 798199
That’s the T Spec distribution block, it also has remote wire distribution at full 12 volts so you can power on everything without daisy chaining your remote lead.cool, a power fuse holder and ground in one box! Noice! What is that above? I also need to brace the trunk mat...so mine will be ugly for sure. I already bought the carpet. Didn't think about just painting the wood!
I may find a shop to do a plexi-glass deal depending on how it looks. Need to get the car back together...this morning's drive to work was LOUD!
Are you running RCA or optical? Did you set the DIP switches correctly? Lastly did you hook a PC to the PAC and make sure your settings were correct?Finished amp rack wiring today! Did a test startup and the amps aren't turning on. Checked voltage and the main batt lead has power to each amp. No voltage on rem. So I looked under the dash where the PAC AP4 is and there's a single red led on. I haven't plugged in the USB yet, but I figured it should work out of the box.
Any suggestions? I'll troubleshoot more tomorrow.
Check the manual, I don’t recall. If I remember correctly there is a master volume control which requires the knob being plugged into it.Running RCAs. All dip switches are up (default). Haven't hooked up to a PC yet...is one red led good or bad?
Make sure you hook up to it with a laptop and check all the software settings.Mmmm...I didn't plug that in. I'll try it and let you guys know
