2023 Mach 1 batteries
Dffej49
Pennsylvania
Grabber Blue 2023 Mach 1 w/handling package.
Do 2023 Mach 1s have gel type batteries and can you use a basic Battery Tender trickle charger when storing them for the winter?
Jerryinpa
North West Pennsylvania
Jerry
2022 mustang gt
Jerryinpa
Jerry
2022 mustang gt
Also,
Motorcraft AGM96R for a oem AGM battery is more up to date part number than the BAGM-48-760 that I previously referred to...
Rob_R
Virginia
Robert
SPF Cobra, 26 Jeep Moab 392, 24 Power Wagon, 88 Jeep YJ
As @Jerryinpa said you could upgrade to an AGM in the future. However, to answer your question, your car was supplied with a flooded cell battery. You can future proof by purchasing a battery charger/maintainer that is capable of charging both flooded cell and AGM style batteries. There is a difference in charging strategies between the 2 types. I have had very good luck with both CTEK and NOCO chargers. Personally, I would get a minimum of 5A charger/maintainer.
Skye
≈39N
"Skye" Mach1 N2144
https://accessories.ford.com/ford-performance-5-0-smart-battery-charger-maintainer
https://www.mustang6g.com/forums/threads/batter-tender-battery-connection.172738/
I've been using the Ford Performance tender since I received the car; it works great on the factory unit.
Charges batteries up to 110AH and maintains batteries up to 160AH
Unique Desulfation Reconditioning Mode for extending battery life
Built-in ambient temperature sensing for optimum charging
AGM and EFB battery charging capability to include all 12V lead-acid batteries
8-Step charging program
Selectable for smaller powersport batteries
IP 65 splash and dust resistant
Spark proof and reverse polarity protected for ultimate safety
True "plug and play" operation. Connect it and forget it
Significantly extends the useful life of your battery
Optional rubber bumper for protection: M-10300-COVER
