2023 GT Performance Pack Tire Options
oktober
Chicago
2023 Mustang GT
305 square on 11 inch wheels is common for road course use but probably overkill for the street. Two ways to do it. (1) Get 4 rear wheels with +50-53 offset and use extended studs and spacers up front for a rotatable setup. (2) Use wheels with less offset up front so no spacers are needed. Apex sells 19x11 and 20x11 wheels with +26 offset for that purpose.
What size hubcentric spacer would I need for the front if I ran 11 inch with 50mm offset and a 305/35/19 tire?
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
Apex recommends extended studs, 25mm spacers, 2.75* negative camber, and 305/30/19 tires with their ET52 wheels.
Dana Pants
Burlington MA
Dana
2018 GT PP1
If you want to keep the PP1 style wheels, I would recommend buying two more rear wheels to use on the front with spacers and putting 275 or 285 tires on all 4 corners. The car will drive better and now you can rotate, extending tire life significantly. My go-to street tire is Continental ECS02. They also have a 285 I believe, but I don’t see a real benefit.
