The catalog states direct and Port injection.Read through the 2020 Ford Performance catalog.
1) New Gen 3 Aluminator engines available.
Do they use the Predator Block?
Do they use direct injection?
2) No 2018+ Power Packs. Looks like they will never be available.
Cheers,
Anything significantly different between Gen 2 and Gen 3 aside from fuel injection?Read through the 2020 Ford Performance catalog.
Any links? I can't find anything on it.Larger Bore
Bigger Valves
Different Cams
Stiffer valve springs
Different heads
Higher compression
rebalanced crankshaft
different intake manifold
I'm not sure if you are mocking or genuinely surprised. Thanks for the link though, all I could find was Gen II stuff and a link to the Gen 3 5.2L block.Seriously? A simple google of gen 3 gen 2 coyote differences pulled up a ton of links. This one is straight from ford
(its a pdf)
https://performanceparts.ford.com › PDFS › Coyote Technical Reference2
SEARCH DUDE.......I'm not sure if you are mocking or genuinely surprised. Thanks for the link though, all I could find was Gen II stuff and a link to the Gen 3 5.2L block.
Edit: The link is for the Gen3 Coyote. I'm looking for the Gen3 Aluminator.
Why are some folks so hell bent on being self righteous. If it is difficult to post it link, it should be difficult to post a response. Why is this a difficult concept for people? I searched and only found Gen II Aluminators. I even checked Ford NXT to see if they had some news, did a search on Ford Performance Parts, as well as a generic web search.SEARCH DUDE.......
