2019 suspension update
ssteve
northern CA
big truck
Anyone have specifics on what the suspension changes consist of for the 2019 models? I know stiffer front springs and softer tears but by how much? Also are the dampers different or just a software update for how they are controlled?
On the surface it seems without any change to the rear swaybar, the car would be more prone to understeer particularly at lower speeds. Additionally I would expect the car to wear tires horribly uneven when pushed hard without being able to dial in more negative camber up front.
jmn444
United States
Jason
gt350
It has the 350r rear sway bar... and camber plates are an option with the handling pack
jmn444
United States
Jason
gt350
Specifically:
Front springs: 211 lb (19) vs 194 lb (18)
Rear springs: 857 lb (19) vs 914 lb (18)
Front bar: both 34 mm
Rear bar : 24mm (19) vs 22.2mm (18)
That help?
jmn444
United States
Jason
gt350
R spring rates are 240 lbs / 914 lbs for addl comparison...
