Rapid Red
- Nov 4, 2019
- Woodstock GA
- Greg
- GT PP2 RaceRed Roush> Steeda> preformance
- Vehicle Showcase
- 2
2 > 1, I read in a no, above 5 mph, it can be done, not recommended ,Mine is on all the time and works flawlessly. The only time it doesn't blip is at really low speeds if I'm going from 2nd to 1st. Mostly in parking lot situations.
The RPM rise just before moving ........................ killed that, drive a standard transmission just fine.
Took the coupe out today, driving and thinking i'm missing 2 gears. LOL
Car feels loose and a bit squirrely compared to the GT. Not unexpected, about the same power band, different torque range.
If it isn't blipping perhaps you aren't dropping into the right gear. It is possible you are either too high or too low and the ECU is saying "nope".
Too Hi /Too low ......You missed one, if the RPM and speed is matched. No blip can occur, you are at what's known as the sweet spot. Can push the stick into gear without using a clutch.
pep
