2019 Bullitt mods help
Tacswa
2019 Bullitt - Shadow Black
Cold start in Track Mode with the Steeda H-Pipe
OK, How do you get a cold start in track mode? My Bullitt automatically goes back to normal exhaust mode after being shut off. Even when saved to "MyMode". I have to hit the toggle switch to MyMode every time to get back to track exhaust
Elp_jc
None
Yeah, you can do that... BUT have to do it after turning ignition on, and before firing up the engine :).
Racerx009
North Carolina
Anthony
2017 Ford mustang gt non pp
Painted a couple of th9
Elp_jc
None
Hey guys, talking about mods, I'm in the process of waxing my car for the first time, and while doing the front bumper, noticed our Bullitts (and probably all other regular GTs) have a solid triangular piece of 'honeycomb' plastic at the bottom, below the headlights. Is there a kit to convert that into a brake cooling duct? Seems stupid Ford didn't do it with PP1s. The additional benefit would be less time devoted to remove freaking bugs from that impossible-to-clean location :D.
Jasef
Castroville, TX
Jase
2019 Black Bullitt
1) Set up your MyMode with Track exhaust
2) Turn on accessories by pressing the start button one time with the gears in neutral and clutch pedal up
3) Use selector switch to select MyMode
4) Depress clutch pedal and start car
5) Smile
Voo Doo
Surrey BC
Ric
2019 BULLITT DHG
3) Use sector switch to select MyMode
5) Smile
pits a manual input...,it always defaults to quiet start I believe?? But will not stay in other exhaust settings !
Elp_jc
None
Nope. NORMAL mode. That's why there's a special setting to set quiet mode within a window of time :). I set it from 9pm to 9am, just in case I need to leave early and forget.
Racerx009
North Carolina
Anthony
Your a nice guy i do the same thing
