2019 Bullitt headers or driveshaft?
bsenbay
Orange County
Berk
2019 Bullitt
Hello,
I have just added these following items to my cart on steeda for upgrades on my 2019 Bullitt and would like some advice on if they are good mods and worth it or if there is something better:
1) Steeda S550 Mustang IRS Subframe Alignment Kit All (2015-2019)
2) Steeda S550 Differential Bushing Bolt Upgrade Kit - 12.9 Hardware (2015-2019)
3) Steeda S550 Mustang Adjustable Differential Bushing Insert System - Urethane (2015-2019 GT, Ecoboost, V6)
4) Steeda S550 Mustang IRS Subframe Bushing Support System All (2015-2019)
5) Steeda S550 Mustang Billet Aluminum Vertical Links with Delrin Bushings All (2015-2019)
6) Steeda S550 Mustang MagneRide Sport Lowering Springs (2015-2019)
7) Steeda Mustang Clutch Spring Assist and Spring Perch Kit (2015-2019)
8) Steeda S550 Mustang Heavy Duty Braided Clutch Line (2015-2019 GT/EcoBoost)
9) Steeda S550 Mustang Hood Strut Kit All (2015-2019)
10) Steeda S550 Mustang 1" Hubcentric Billet Aluminum Wheel Spacer - Pair (2015-2019)
11) MGW Race Spec Short Throw Shifter
12) Corsa Extreme Catbacks
13) Palm Beach Dyno nGauge Naturally Aspirated PBD Tune (91 Octane main fuel, E85 secondary fuel)
Now I am having a very hard time deciding between a QA1 carbon fiber driveshaft or
American Racing Headers 1-3/4" x 3" with cats (Direct connection for Corsa). I am unable to do both unfortunately so Im not sure which one to do. Any recommendations?
I will also install a whipple supercharger by the end of this year. Thank you!!!!
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I say headers. Go 1 7/8 and be done.
bsenbay
Orange County
Berk
2019 Bullitt
80FoxCoupe, won't I loose power with the 1 7/8 headers? Aren't they for 1000 HP plus cars?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Power loss? No. You mentioned doing a whipple later, so why buy twice?
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
17/8s will make power on an N/A car. The drive shaft will most likely gain you no performance. And will most likely vibrate more than stock.
bsenbay
Orange County
Berk
2019 Bullitt
80FoxCoupe, should I get the QA1 carbon fiber driveshaft first and then get the 1 7/8 headers when I get the whipple then?
boB
boB
2019 GT PP1
According to Car & Driver the PP2 runs 2:53 at VIR and corners at 1.13 G, without any of the items you are considering. The question then is: are any of these necessary?
Except the hood struts, I like those! :)
Jetnoise
Raleigh NC
2018 GT Premium PP1, 70 Shaker Mach 1 stroker, 1967 F/B 357W, 1968 302 Vert, 4I 85 5.0 B&M Blower
I’d go whipper first and see what needs addressing by how you use and drive your car.
Half shafts seem to go hand in hand.
You could always just buy your whole cart too ;)
DuRsT
2020 GT500 - 2006 GT Convertible
I’ve had the carbon fiber driveshaft.
Not worth it IMO, the driveshaft cannot even come close to the gains you would get from headers. It’s easy to forget it’s there...headers not so much.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Get the headers and skip the driveshaft all together.
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
If you are keeping the car a long time any mods OK. But, the suspension parts except for the alignment kit and BMR's Cradle Bushing lockout kit will make cabin noise.
You have Magneride? Why ruin in with the suspension mods? Unless you want a harder ride, noisier, etc. I've had every one of those mods.
I've had both driveshafts: aluminum and carbon fiber. They make more cabin noise because the heavy stock DS removed some of the tunnel noise. Ford designed all this to make it work together.
Keep your money and just do the blower. Get a compentent shop to tune it. Make them show you the AFR and be anal about it. Because once it's tuned your warranty will be void for powertrain issues. I do believe the Bullitt would be awesome with a blower. Forget the rest.
These cars DO NOT need to be lowered. I like Steeda a lot. But, you do not need to lower your car.
