My memory doesn’t serve me well and I can’t double check as the beast is in its winter slumber. Have you gone through the dash settings to see if there was a setting there? In FORScan you have to check the IPC config if it’s there. I doubt you will see any thing in the APIM or BCM modules.
I've looked through and it doesn't show in any mode. I dont see any option to enable it... weird.If you are using sport or track mode I believe it does not allow the song to show because the tachometer occupies that area.
I can confirm that temp and song info do show regardless of display mode. I have my dash locked in Sport mode regardless of actual mode (there's an option to lock it).If you are using sport or track mode I believe it does not allow the song to show because the tachometer occupies that area.
Has anyone seen an option to turn it on/off bc I’m totally lost as to why mine isn’t showing up...I can confirm that temp and song info do show regardless of display mode. I have my dash locked in Sport mode regardless of actual mode (there's an option to lock it).
i'll snoop around when I get off work but I did notice yesterday when in normal mode I can see the song playing, when in sport mode, it'll show when the song changes, but does not stay the entire time.Has anyone seen an option to turn it on/off bc I’m totally lost as to why mine isn’t showing up...
Yeah, that's what I meant earlier. I keep my gauges in Sport mode (you can lock one of the modes in just for the visual) and it does show the song only when it changes. Apologies for the confusion.i'll snoop around when I get off work but I did notice yesterday when in normal mode I can see the song playing, when in sport mode, it'll show when the song changes, but does not stay the entire time.
I don't know how to do all that forscan mode stuff...my last car had no special things to it so im getting used to Bluetooth now.Display FM Radio Song Playing
720-05-01 X*XX XXXX 0 = Disabled 8 = Enabled Shows current song on FM radio. Only if you have HD
radio. BT/USB displays song still when set to 0.
But it shows the extra info for me when in track/drag modes (not the other way around) so that doesn’t make sense.I would venture to guess that in track/drag modes they want you paying more attention to the road so they keep the screen less busy. Nav does show up in sport mode, that's where I tend to keep mine in, as long as you have it set to the "blank" screen when not running nav.
just making a comment for now, might look into that sort of thing in time. changing the pony entrance and exit screen seems like a fun thing if im able to change it to cross hairs or something like that, is that possible?Not sure if you are asking for help or making a comment.
no worries. You can change the startup and shutdown screens. I changed mine from the mustang horse to the GT screens. Also the UI changes a bit but I like it.just making a comment for now, might look into that sort of thing in time. changing the pony entrance and exit screen seems like a fun thing if im able to change it to cross hairs or something like that, is that possible?
how does police (dark) mode work in MT vehicles? I did a few of the others today when I got my OBDLink but doesnt seem like police mode would work for our vehicles.Sync3 Startup /shutdown w/ Ford GT animation, disable double honk reminder (engine on, No keyfob), Simultaneous high beams & fog lights, Police(Dark) mode, Set powerpoint to 1 second after engine shutdown, enable average speed screen
