2019 5.0 center shifter "S" position verse Sport mode +
Discussion in 'Mustang S550 General Forums' started by Chopps, Jan 25, 2019.
  1. Chopps
    Chopps Well-Known Member
    Vehicle(s):
    2019 GT
    Dec 29, 2018
    Georgia
    Is there any difference when shifting the center consul into S ( below drive @ bottom ) position than using the toggle switch to put it in sport mode other than the obvious change of the display on the dash ?
    Just curious if anyone has tested that and are shift points and all different.
  2. FruityJudy
    FruityJudy Well-Known Member
    Vehicle(s):
    2018 Mustang GT A10
    Nov 13, 2018
    South Alabama
    461
    301
    0   0   0
    I can tell this shifting and throttle response in s mode is not as aggressive as sport plus. I used to drive in sport plus all the time until i started running in s mode and I like it better for daily driving
  3. michail71
    michail71 Well-Known Member
    Vehicle(s):
    2018 GT 401a A10
    Apr 15, 2018
    1,134
    173
    0   0   0
    That keeps the other parameters such as exhaust, steering and magnaride the same.
    It also activates full time and real manual mode on the shifter paddles.
    I've also observed it tends to downshift much more aggressively when shifted to S. I the manual says to use it for downhill driving.
  4. choate
    choate Well-Known Member
    Vehicle(s):
    2018 GT A10 401A with Active Exhaust
    May 22, 2015
    Fort Worth TX
    395
    158
    Rating:
    100%
    2   0   0
    It’s kind of annoying when you toggle through the dash modes and you want to go back to normal it has to go through drag then ice/snow and then normal then back to my mode. It’s fine if you just put it in one mode and go but I like to leave mine in D and my mode for track exhaust and if I want more upshifting or leave at a light and have fun it’s much easier to just put the shifter down one notch then when you’re back to putting along with traffic just one notch back up on the shifter to D. Way easier
  5. choate
    Vehicle(s):
    May 22, 2015
    Fort Worth TX
    395
    158
    Rating:
    100%
    2   0   0
    As mentioned the other thing is the dash mode to S+ will put the steering into Sport which is too stiff for my liking on the street. It probably does shift different though. I haven’t really compared
  6. showbbq
    showbbq Well-Known Member
    Vehicle(s):
    Nov 21, 2018
    Houston
    129
    108
    0   0   0
    Yes, the shifting is much more aggressive in Sport+. You should use 'D' for city driving and if your grandma wants to drive it. On the highway you should use 'S' at minimum. Don't worry I'm pretty sure this is all in the handbook.
  7. sdiver68
    sdiver68 Well-Known Member
    Vehicle(s):
    18 GT PP1 10R80 Vert
    Jun 28, 2018
    St. Louis
    721
    405
    Garage Profiles:
    Occupation:
    Business and Information Systems Management
    0   0   0
    Im hoping when I add the Lund tune they can give me a hybrid S + D mode to replace the normal D mode.
    The new D mode will have throttle response and acceleration shift strategy of S, but the shift pressure of D and without the rev matching downshifts of S.
    Short of that, I think just mapping the throttle response of D more aggressively might achieve most of what I'm after.
  8. michail71
    Vehicle(s):
    2018 GT 401a A10
    Apr 15, 2018
    1,134
    173
    0   0   0
    Every time I point that out everyone jumps on my case about how wonderful it is and the most amazing design in automotive history and Ford can do no wrong, lol.
  9. Jons5.0
    Jons5.0 Well-Known Member
    First Name:
    Jon
    Vehicle(s):
    2018 Oxford White GT Auto 301A Black Accent
    Nov 2, 2015
    Albuquerque
    255
    118
    Rating:
    100%
    2   0   0
    I cant tell you the difference if there is one in S vs S+ in throttle mapping but be careful when in S mode on the shifter as there is a difference if you use the paddles in S on the shifter that will put you completely in manual shifting mode and will not shift automatically like S+ will.
    Gtgpa likes this.
  10. Ed M
    Ed M Well-Known Member
    First Name:
    Ed
    Vehicle(s):
    2018 GT convertible
    Jun 30, 2018
    Las Vegas
    354
    278
    0   0   0
    It is wonderful. It is safety through design. Ford doesn’t allow the mode to change unless it is very deliberate. First, the switch must be pushed up just to turn the toggle on. Subsequent up-toggles will change the mode and then the switch will turn off automatically after a short period of inactivity. Allowing for down-toggle increases risk of accidental operation, for example, if the passenger reaches for something in the tray and accidentally bumps the switch.
  11. choate
    Vehicle(s):
    May 22, 2015
    Fort Worth TX
    395
    158
    Rating:
    100%
    2   0   0
    Just to confirm if you’re on S+ on the dash it will shift automatically if you are using the paddles and the gear selector is in D?
  12. Idaho2018GTPremium
    Idaho2018GTPremium Well-Known Member
    Vehicle(s):
    2018 Mustang GT Premium A10 w/ PP1 and MagneRide
    Nov 20, 2018
    Idaho
    767
    484
    0   0   0
    Putting the stick in "S" simply puts the car into manual shift mode near as I can tell - I haven't noticed any other differences other than that. You can still toggle the modes while in S. I think of the "S" as short for "standard" (i.e., manual) mode, I don't think it changes the suspension or steering compared to simply having it in D if you don't change the drive mode with the toggle.
  13. choate
    Vehicle(s):
    May 22, 2015
    Fort Worth TX
    395
    158
    Rating:
    100%
    2   0   0
    Way off man. It holds every gear upshifting in S and doesn’t skip. Shifts much quicker and also hits every gear on the downshifts when coming to a stop. Also HUGE differences when on throttle input on when it upshifts. In D you have to really almost floor it in order to get it to grab a higher gear. It holds the gears MUCH longer too. Ur post is bad info in my opinion
  14. Mustangpursuit
    Mustangpursuit Well-Known Member
    Vehicle(s):
    Mustang GT/CS 2019
    Jan 17, 2017
    California
    913
    222
    Garage Profiles:
    S shift gives me sporty or mountain/hill use automatic, as long as I do not touch the paddles. S+ is sporty, but if I shift to S while in S+ it becomes a more aggressive shifting A10 vs S+ and D.
    choate likes this.
  15. Idaho2018GTPremium
    Vehicle(s):
    Nov 20, 2018
    Idaho
    767
    484
    0   0   0
    Who are you talking to, me? Putting the shifter into S mode doesn't change the drive modes, it puts it in manual mode. And yes, even with the shifter in S it will downshift automatically as you slow down to a stop. Note that I am talking about the shifter, not the toggle modes.
Loading...
Share This Page
