2018 S550 intake replacement
rall
niagara falls
rejean
2017 mustang gt convertible
Hello all, trying to get some feedback on upgrading my 2017 intake to a 2018 intake, currently i have a JLT CAI, Borla S-Type Exhaust and Kooks long tube headers, The tune is a SCT 91/93 stock tune, i have done some research and found that it would give approx 15-30 wheel HP however i have been told that it could be tricky to tune by the guys that installed everything and they couldn't give me a great answer so i'd love to hear any success stories.
EFI
Masshole central
5.Br0
First of all you're not going to gain anywhere near the high end of that range. You might get 12-15 at the very top of the range. Those quotes you are seeing are usually the tune + the intake combined, but you already have a tune.
It shouldn't be tricky to tune by a competent shop, especially if they don't have to deal with the IMRCs which you should be locking out. You can probably even run the current tune and it will be ok.
CrackedHorn
Kansas
09 Mustang GT/CS; 15 Mustang GT
Install is pretty easy. There are several tutorials online
Bang for the buck is pretty good on this platform if staying NA. CJ intake will make more power but it'd all up top at 7k+ rpm.
Tune should be straightforward for any decent tuner
You will probably see ~15hp if I had to guess.
rall
niagara falls
rejean
Thanks for the responses.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
You will not see any gains over your JLT. If the JLT is an open design you will see lower IAT's with the 18.
CrackedHorn
Kansas
I thought OP was talking about intake manifold. Not thr CAI
rall
niagara falls
rejean
I am trying see If a 2018 intake manifold will give me a little extra hp with the existing bolt ons and tune, again I have a jlt Cai,kooks long tubes with x pipe, borla s type and a 93 tune
K4fxd
NKY
Go with the GT350 manifold. There is a reason Ford puts it on all the flagship cars.
GregO
Illinois
S550 GTPP
2015-17 S550 5.0 w/GT350 manifold x 80mm TB or 87mm TB, IMRC remain 100% functional FTW !
Push the rev limit to 8k FTW+ !
You will not regret this combination.
rall
niagara falls
rejean
Is there any modifications to do as I have havent looked into it, what kind f gain would I be looking at?
K4fxd
NKY
It's plug and play if you use a throttle body adapter and your stock throttle body. It revs higher than the 18 GT manifold.
