2018 Mustang GT P0300 code
gmupatriot
Northern VA
2018 Mustang GT (Orange Fury), 401A, A10, 3.55
Hey everyone,
The car has 20,xxx miles on it and its exactly a year old. This morning when I started this car after being parked since Friday, I got a CEL (it was around 12F outside). I drove it to work and it drove perfectly fine. No rough idle or hesitation of any kind. On the way back from work I stopped by Auto Zone and had the code pulled (P0300 random misfire). It did not specify any other code as to which cylinder the misfire is at but that is all the ODBII reader gave me. Since the car is driving fine, should I just drive it for a couple of days and see if the CEL goes away or do I need to head to the dealer?
Thanks
66Bronc1
South West Florida
JT
Mis- fire from very cold weather is possible. I would drive it a couple of days and see if it re-sets. If not go to the dealer or borrow and ODBII from someone and re-set it yourself.
Condor1970
Port Orchard WA
I had one too. I think it may have been the 87 octane gas. Not sure. I took it in, and they did a relearn of the PCM since they previously installed a new clutch. Hasn't happened again.
gmupatriot
gmupatriot
Northern VA
Thanks for the response. I have never had a new car throw a CEL so I was concerned but it seems to be driving fine.
gmupatriot
gmupatriot
Northern VA
**Update**
After driving the car for approximately 300 miles, the check engine light went away. It seems the misfire was a one time thing on startup on a really cold morning.
gmupatriot
gmupatriot
Northern VA
The CEL and code is back again. Same thing, drives fine but when I started is this morning, the CEL came on again. Could this mean it will just do this occasionally because there was a hiccup on initial startup? The car drives fine so I am guessing nothing is actually wrong?
sZedely
Lake Orion, MI
Aaron
2019 Mustang GT PP1
jhunt47
Arkansas
Y
2018 mustang gt
I would take it in to the dealer and have them look at it. They can see misfire history for each cyclinder and let them fix it.
gmupatriot
gmupatriot
Northern VA
I would take it in to the dealer and have them look at it. They can see misfire history for each cylinder and let them fix it.
Thanks, I will be doing so because this is the second time it has popped up in 2 months and a new car shouldn't be having these issues.
2018MUSTANGGT10R80
Wisconsin
From the owners manual, Your vehicle is equipped with a lifetime fuel filter that is integrated with the fuel tank. Regular maintenance or replacement is not needed.
gmupatriot
gmupatriot
Northern VA
I've just had this exact issue the other day. Taking it in tomorrow.
I took mine in and by the time I had the appointment, the CEL went away. They were able to pull it from memory and said it was probably a fluke and since the car drives fine there is nothing to worry about. I told the tech this is the second time this happened and his reply was next time bring it in the moment I get the CEL. I called the next day when this CEL came up and they gave me an appointment that was 5 days in the future by that time the CEL went away. Go figure.
cmoneys550gt
Ontario, Canada
Craig
Yes they are telling me it's probably a glitch. Said to bring it back if it happens again.
SamB11
Mississippi
Sam
Any update on this? Mine started doing it as well
