2018+ GT swayers
myblkshadow19
texas, usa
chris
2019 ford mustang
so what's the consensus on swaybars? brands etc.... i'll take any feedback. seeing a bit of sliding rather than the car biting in some tight corners. now i realize it could just be tire grip and I've gotten to the end of what the street tires will provide. thanks
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's all a compromise. Balance the car for when you push it most often. Adjustable bars are your friend
Excelerater
Memphis TN
2015 GT
I added Steeda Sways,I think the rear sway was the biggest difference but
adding new sways,with tighter shocks and all these little items add up to a better handling car
i do not think brands vary that much and they all copy each other here and there
myblkshadow19
myblkshadow19
texas, usa
chris
2019 ford mustang
already have their struts and shocks and their progressive springs. also did the subframe braces, lat links, front g brace, irs bushings.....and jacking rails. i mean it'll hugh side light an off-road vehicle on certain inclines, also had an alignment done with some specs that are more than stock setup to help get it to bite in corners. but without having sway bars i didn't know how the will help....
NightmareMoon
2016 Mustang GT PP w/ Voodoo
If you're sliding, its probably tires. Swaybars help with transitional response for fast switchbacks or high speed lane changes. They won't really add grip, that's the tire's job.
Bluemustang
2015 Mustang Base GT
Yeah its tires. And in most cases stiffer sway bars reduce ultimate grip levels.
myblkshadow19
myblkshadow19
texas, usa
chris
2019 ford mustang
well hell, definitely feel flat so not sure sway bars are needed just yet, maybe for track days but on tight scca events it's more sliding. think it's time for some road race/autocross event tires. too 888r's or maybe even some cup2's.......
NightmareMoon
What are you on now?
tj@steeda
Timothy
Here is a great video on our rear swaybar - let us know if we can help assist with any suspension questions you may have - you can reach us at [email protected]
myblkshadow19
myblkshadow19
texas, usa
chris
2019 ford mustang
awesome! looks like a rear bar and the end links with the billet mounts are in order hopefully soon. thanks tj
NightmareMoon
mustang5o
Middle America
2023 Oxford White Mach 1 Handling Pack
Anyone out there running without a rear sway bar? I've heard some people do and the rear end won't step out on you as much. Trying to decide if I want to try it or not.
