2018 GT non PP1 auto vs PP1 auto
theonewangsta1
Silverado
Can anyone tell me if there’s a major advantage between the two? How much faster is one than the other?
Timeless
South Carolina
2024 Grand Highlander Hybrid Max Limited
Check out the search as this has been discussed many times.
I'm assuming you are talking a straight line single run?
If so, the PP1 would only be faster due to stickier summer tires and possibly the 3.55 rear.
However for a single pull it would most likely be whomever got the jump.
steph93lx
Montreal area
2018 GT 301A A10, Modded N/A 1993 coupe 5.0L
The non pp2018 is not bad at all it got a similar suspension than the pp1 of last year's.
If you talking about faster as far as roadholdind the pp1 is faster stock for stock.
If you talking in straight line a non pp within the same trim will be a little bit faster du too lower weight than a pp1.
In straight line the fastest stock 2018 GT is a 301A (base with drag mode) A10 3.15 or 3.55 optional gear with the optional active exhaust.
However the 3.15 car have a lighter by 20 lbs aluminum housing differential.
The only real downside of a base 301A are the 18" ridiculous 235 tires. I sold my stock wheels and tire, problem solved!!
