88lx50
LSPI at idle? I would think you would need some kind of load on the engine to cause pre-ignition. The video posted is a car under load, experiencing LSPI.
Is that in D or S mode? If not D, does it do it in D? Does it get better when engine warm?
Heres mine sounding bad.. Ceratec fixed my bbq tapping but now I have this =/ Dont think it was this loud before. I do have 3k miles on my oil so I will try getting it changed hopefully that helps. Probably going to 5w30.
Car still seems to run great though. Sucks that they have so many weird sounds.
It was in S mode , in D I dont think I could hit that RPM with the low amount of throttle needed to cause the noise it may shift below that RPM. It does seem to get somewhat better when warm but not perfect. I am on e85 and it seems to have got worse since switching to that =/ No knock on most of the logs though. Ill datalog through that RPM range today. Also going to get an oil change asap and if that doesnt work ill go back to stock and see what the dealer thinks. I already was in line for the light rev rattle fix according to the dealer but the exhaust cam phasers were backordered..Is that in D or S mode? If not D, does it do it in D? Does it get better when engine warm?
Ceratec fixes that one but then you may get the 2k rpm rattle lol
I know this is the rattle thread but after my first oil change I get the typewriter tick randomly. It comes and goes. Yesterday was the worst one yet.
mines an auto and has the rattle...I believe I have figured out the acceleration rattle. If you hold the shifter to the left or right while accelerating it amplifies the noise....the exact same noise. I believe it is either the flywheel or pressure plate, resonating through the engine bay.
Someone else with the rattle try this and see if it makes the rattle louder. It would also explain the clutch grinding at high rpm.
Just because he can change the rattle with the stick doesn't mean it's directly related to the clutch.mines an auto and has the rattle...
Hi all ...I have a 2018 GT PP1 w/ 6MT and had this rattle since about 500 miles on the car. Manufacture date was 11/15/17. I started as a minor rattle only when cold and over 3k miles, presented itself across all temps. I read all the posts in this thread and headed off to the dealer armed with a binder of posts and picture from this forum. I asked the tech to ride along and was able to replicate the noise within seconds. I showed him all of info from this thread and he seemed appreciative. Later that day, dealer called and after the tech consulted with Ford, Ford authorized a short block replacement. Dealer didn’t do much more than stethoscope validation of the noise in the bottom end of the engine. For Ford to authorize a short block so quickly, this must be a growing problem. Service advisor at the dealer said this was the first time they experienced Ford authorizing a short block without detailed troubleshooting and pics. Quick thanks to everyone who took the time to document all this. Dealer said factory is shipping the engine on 21st, so hopefully I’ll be back in the road sometime in January.
Some wear is normal. It all depends on how the car was driven. Looking at the computer memory will be one thing needed to determine that. Like the small scuff line second from the big one on top. If it was just that, with a couple tiny lines, I would say yes it's normal. But with the low miles, and several large scuff lines, NO. That is too much cylinder wear for the low miles of the vehicle. Unless it was dedicated weekend track car, drag racing, and that wear is from 500 miles of peak rpm, then yes, it could be normal.I'm sure some will say that is normal wear LMAO.
The only line that I would find acceptable is the one in the 6 o clock position, those black marks are not normal.Some wear is normal. It all depends on how the car was driven. Looking at the computer memory will be one thing needed to determine that. Like the small scuff line second from the big one on top. If it was just that, with a couple tiny lines, I would say yes it's normal. But with the low miles, and several large scuff lines, NO. That is too much cylinder wear for the low miles of the vehicle. Unless it was dedicated weekend track car, drag racing, and that wear is from 500 miles of peak rpm, then yes, it could be normal.
Of course they can be, it just depends on how hard it was driven, and for how many miles. If that car had 30-50k miles, I would say it's perfectly normal. But if it only has 10k, then it may be a bit much. Although at 10k, if it was drag raced on weekends or lots of frequent pulls, then yes that would be normal.The only line that I would find acceptable is the one in the 6 o clock position, those black marks are not normal.
