2018 GT 1st gear launch stutter MT82
Enzo
Orlando
Enzo
2018 Mustang GT PP1
Hey guys!
I am having a interesting issue and couldn't find any information on here. Has anyone had a issue where 1st gear take off has a sort of two step stutter. It almost feels like the clutch is stuck and not letting go properly and the plates are stuttering.
Thanks!
Kong76
Turlock, Ca
2016 Ingot Silver GT
I usually get some chatter with my oem clutch if I don't give it enough rpms before takeoff. Not sure if that is related to your post or not.
Enzo
Enzo
Orlando
Enzo
2018 Mustang GT PP1
mine isn’t from that. It gets enough gas it feels more like the clutch is stuck. But I do get the chatter as well.
Jetnoise
Raleigh NC
2018 GT Premium PP1, 70 Shaker Mach 1 stroker, 1967 F/B 357W, 1968 302 Vert, 4I 85 5.0 B&M Blower
Traction control?
Or launch control setting?
Enzo
Enzo
Orlando
Enzo
2018 Mustang GT PP1
Sounds like the tob is not working properly.
Could be, it rarely does it and when it does it’s mainly in the morning after driving it for about 30 mins on highway and then coming to local roads.
Enzo
Enzo
Orlando
Enzo
2018 Mustang GT PP1
Enzo
Enzo
Orlando
Enzo
2018 Mustang GT PP1
Jetnoise
Raleigh NC
I'd guess your traction control might be activating and it sends a shock through your driveline
Turn of the traction control and see if it helps
GregO
Illinois
S550 GTPP
You may want to look over the clutch flex hose quick connection at the fluid reservoir/ brake master.
There’s a long thread discussing how the connection isn’t properly seated from the factory assembly line that result in clutching issues.
Check it out as your first line of defense.
DuRsT
2020 GT500 - 2006 GT Convertible
Sounds like you're losing pressure in the hydraulic system for the clutch to me. Check your fluid level to ensure you're not losing fluid.
