2018 Ecoboost battery problems..?
vetonater
Tennessee
Brad
2018 Mustang EB/ 2022 Oxford White Mach 1
so just to give you guys a back story, randomly one time last year I went to start my ‘18EB one day and the battery was dead, I took it to have the battery tested and they said it was perfectly healthy..
Last week I turned my car off to put gas in it, and it would not start back. The voltage from the dashboard was ~9v, I let the car sit and it somehow got to about 10v and it eventually started.. after maybe 5 failed attempts of waiting, now whenever I turn my car off the battery immediately drops to 10v, and I Will immediately start it but is very slow at turning over, I’m worried if I let my car sit over night I will come back to a completely dead battery. The only thing I’ve changed is I have a 93 octane tune, and I just flashed it back to stock prior to these things happening, coincidence or related? Thank you for the input!
Reddirocket27
South Jersey
Jeff
2018 CPO EB Prem Conv w/ 201A
Tbh, I replace batteries every 3 years, no matter what. A single loose cell can cause a hard (or no) start. Batteries are incredibly cheap nowadays.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Ya, stock (and most aftermarket) batteries older than 3 years are on borrowed time. Just get a new one, its far more likely that the battery is just at the end of its natural life than anything tune related.
its not uncommon for a dying batter to pass the test and then fail it the very next day. BTDT. Now I also replace batteries at 3 years -replacing them before they fail is a lot less annoying than it being a surprise.
vetonater
Tennessee
Brad
Any different batteries I should look into getting? Or another stock one
ORRadtech
Atlanta, Georgia
I don't know who tested your battery but they were likely incompetent.
Without competent testing by you or someone qualified to verify Icouldn't say for 100% but I'd be willing to bet you need a new battery.
My '18 EB is 1 year into its second battery.
Newer cars that are heavy with technology are very hard on batteries.
vetonater
Tennessee
Brad
Thank you for the input, I was thinking it was the battery as well!
Check battery terminals for corrosion, make sure terminals are lean at the posts and inside the harness terminal rings. Also check for any poor/loose grounds at inner fenders near radiator support.
