2018 EB PP Speed Limiter
SVO MkII
IL
2018 Ecoboost, 6sp, PP, 2017 GT Convertible
I just picked up a 2018 EB PP 6spd. Is the speed electronically limited on this car, and if so, at what speed? I've searched but can't seem to find any info on this.
Thanks.
Matco
Camarillo Ca
2019 F150 2018 Mustang GT 1996 Ford Bronco
164mph
SVO MkII
SVO MkII
IL
Matco
Camarillo Ca
I believe electronic
MaxHedrm
Dallas, Texas, USA
Scott
2018 GT Convertible - Orange Fury
It wouldn't be drag limited, it's too low. Probably not gearing either, considering how many overdrive gears both transmissions have. That's probably electronic for tire rating (or insurance ratings).
SVO MkII
SVO MkII
IL
Just for clarification, I am talking about the Ecoboost. I loaded all the ratios into a gear chart calculator, and the "theoretical" top speed at 5500 rpm is 180 mph (thanks to a .70 6th). But lets be honest, there is no way 310 hp is pushing a 3500 lb car with this much frontal area to 180 mph. I suspect 155-160 tops. Which is still PLENTY. The fastest track I will drive is Road America. I can't see myself exceeding 130 by much. I just want to make sure the speed isn't limited to say, 120. That would piss me off!
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Is that electronically limited, or drag limited?
At stock power, I doubt there's much difference.
You'd be lucky to get within 30 mph of that on most any road course anyway.
Norm
kenkroop
new jersey
KEN
2018 gt a10
My 2016 EB was electronically limited at 120.I don't know if there has been any change. With a Cobb Acessport limit could be raised in 15-17 my.
SVO MkII
SVO MkII
IL
Was your's a Perf Pack car? I read that the 120 limit may have been tire related. Since the Perf Pack comes with the "summer" P Zeros, it may be higher. But again, I don't know for sure.
HoosierDaddy
Randy
Or other parts. 2011 V6s had a ~114 limit and people assumed it was for tires until some removed the limiter and found their cheap drive shafts coming thru the floor. A limiter can be for the tire rating but also for other unpublished part limits.
SVO MkII
SVO MkII
IL
It's certainly possible, but my understanding is that on current models, many of the components are shared across the entire model line, e.g., gearbox, differential, etc. This may have to do with the much closer gap in torque between the Ecoboost and the V8 (350lb/ft vs 420lb/ft).
I suppose I could try shooting a message to Ford, but I'm not too confident I'd get a reply.
MaxHedrm
Dallas, Texas, USA
Scott
Ooops. Yeah, totally missed the EB. :D I might be a little 5.0 fixated at the moment.
SVO MkII
SVO MkII
IL
I understand. I could just sit and listen to that V8 sound all day:headbang:
