Buttonwillow Raceway EB PP
Status
Not open for further replies.
Anthony@HTM
Anthony@HTM
SF
GT350 Track Pack
Did you make them from scratch?
They look like an existing piece that was modified.
The existing fog light bezel was trimmed but everything else was hand made.
K3NMasterS
Chicago
a 5.2L Flat Plane
Here's a question for you since you have tracked your car in the heat many times now. I presume you remove the spare tire cover and foam air pump from your car for these events, which leaves the inside of your trunk exposed to more heat resonating from the exhaust. Has your back-up camera stopped working immediately after a session when you pull off the track and into your paddock space?
I don't know if it's the heat, but it can be the only culprit. I'll put my car in reverse and the display won't go into camera mode. I've checked the setting and there's no setting to actually turn the camera on/off. It will start working shortly after cooling down. I want to take this to Ford for a warranty claim, but how will I replicate this without telling them I was racing the car..?..
Anthony@HTM
Anthony@HTM
SF
GT350 Track Pack
I wish I could help. All of the trunk comes out at each trackday but I never have issues with my back up camera.
I also have a single exit exhaust which may help with radiant heat.
Status
