2018 Digital Cluster Installation Guide
z06psi
Evans, GA.
Andrew
The pot stirrer
If you read the FAQ I explain what the deficits are with SYNC 2. All you lose is the nav and song title in the cluster.
Thanks. ON Sync3 with Nav now.:headbang:
zero_chance
Dismember
Arizona
JD
2017 GT Premium w/ Performance Pack
Finally went back in today and added a few more strips of foam tape. 100% rattle free under all conditions.
z06psi
Evans, GA.
Andrew
The pot stirrer
zero_chance
Dismember
Arizona
JD
Behind the digital cluster.
zero_chance
Dismember
Arizona
JD
As part of the original install, yes. This go round I hit a few other areas, so not sure what one actually solved the minor rattle, but it’s gone.
z06psi
Evans, GA.
Andrew
The pot stirrer
zero_chance
Dismember
Arizona
JD
When you have the old analog one out, you’ll see some metal bracing in the dash that needs to have some put on it. The back of the digital cluster has aluminum fins for cooling, I wouldn’t apply any on it directly but kind of visualize how the cluster sits in there and apply anywhere you think there’s a chance it could move and cause a rattle. I’m pretty sure I was getting some from the plastic shield that was cut out hitting up against the air duct behind it. Like I said though, I didn’t want to try just one spot and have to tear it all apart again so I was more liberal the second time around.
breeves002
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
You want to make sure your foam isn't too thick. If it is the cluster will bounce off of it and rattle against the bezel.
breeves002
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
Looks like Bezels have been released....The 3 I had ordered came in today!
SCCMs are still in hard to find supply. I had 2 come in yesterday but more are still backordered.
djcwardog
V8 Driver
Central KY
2016 Mustang GT Base with PP
Yes! Mike emailed me to say that he had all my parts together and they would go out today. Now to worry about a heated steering wheel! As for active exhaust I may just see about a setup like Sam did. Maybe he could make up and source the switch and transformer boxes for me?
breeves002
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
If you send me your motors I'll happily set them up for you... just send me a PM if you're interested.
Good luck on the heated wheel. So far no one has gotten it working...
zero_chance
Dismember
Arizona
JD
I'm in Arizona, so I have built in, no charge heated steering wheel all the time. Switching to the GT350 wheel really helped with the suede. In any case, surprised no one has gotten it to work yet. Seems like it wouldn't be too bad compared to the cluster swap. Wonder if it has its own separate module.
breeves002
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
It does have its own module, and we've installed and wired and programmed it. Doesn't work....We're trying extreme things.
