2018 Digital Cluster Installation Guide
breeves002
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
this is too easy!! i would like to do it by myself!! LOL let me learn how to do it!! thank you anyways!!
Hey if you want to support me I'm happy to build the files. Just FYI I have given out all of the necessary information to enable all of those things in the spreadsheet, you must have missed it :p
1222nap
Lithuania
Mustang
Hi, anyone can read and share eeprom data of manual car with digital dash and KPH speedometer?
Im unable to change MPH to KMH gauges propertly on manual car because there are left DTC U3000 in IPC, besides it working propertly
VIN code or F188 calibration of UCDS also could help
Thanks
Blade007
North East
2017 Mustang Ecoboost Magnetic, 2011 Nissan quest
apologies if this has been answered but is there a way to have the posted speed limit show up when using nav on the digital dash?
Thanks
Blade007
North East
I'm not sure. My son has a 2014 fusion and his shows the posted speed limit on the dash. I thought there would have been a way to add this to the digital dash
randy_tho
Tennessee
Most of these mods can be done cross model when the hardware is the same but the as built software has been tailored/configured a certain way. Then that can be changed to "unlock" the feature. My guess is the cluster is different so its not going to be common enough. Plus the sync system is likely different also.
The RedMus
Miami
Diego Certified
2015 Mustang 50 Year Edition
you were right!! i missed the most important part! i did the base programming and everything is back, thank you for this great job! this information is super value to help guys like me that like to do thing by my self! keep us on the loop!!! :clap:
Blade007
North East
Hi Guys
Is there anyway after you upgrade to sync 3.4 to get apple maps or google maps or waze directions to show up on the digital dash?
Thanks
OrangCrush
2015 Mustang GT Auto 3.55 - X pipe,Roush axleback
I having issues with rattle noise. Driving me bananas. I have some foam behind it but sound like it’s coming from bezel. Anyone have this issue?
randy_tho
Tennessee
Possibly check at the top middle front of the clear plastic. From pictures these tend to vibrate there and it causes some marring. Maybe that is the source of the noise.
rubens_5.0
Los Angeles, CA
Ruben Rolon
2016 Mustang GT PREMIUM PP ESS G3 SUPERCHARGED
Having same issue and does look like it is front top middle as if i push it in it stops making noise but dont know of a permanent solution i couldnt do the drill method since i took off to much plastic when i cut it for the digital gauge cluster but was thinking of just replace the whole dash for a 2018+ dash pad and hopefully fixing this issue but idk if they fit on 2015-2017
randy_tho
Tennessee
My first thought would be some of that felt tape stuff. Ford used it a lot on the S197 to cut rattles. If you can put it on the bezel where it is not visible it may wedge it enough to relieve the issue. (Given the cluster is otherwise secure and doesn't eventually shake apart.)
rubens_5.0
Los Angeles, CA
Ruben Rolon
I was gonna use foam pad but i think that might be too big and visible for the bezel an its gona be on the cluster
OrangCrush
I took every piece off one by one and took it for a drive each time until I was left with just gauge cluster. I found out it is the bezel. I have a video of me tapping the bezel where the chrome piece connects to the black plastic piece. I don’t know how to post videos on here.
rubens_5.0
Los Angeles, CA
Ruben Rolon
Youtube and post link?
