2016 s550 Base - Rear Differential Fluid change
Ninpop9
Illinois
2016 Ford Mustang
I am curious on how you guys maintain your differential fluid. I have been in the habit of doing it every year mostly since where I live I daily drive in a winter climate three months out of the year where the limited-slip sees a lot of wear and tear.
Do you lift all four tires for the fluid change or do you somehow fit under the car to where its level enough to refill the oil. I've been trying to figure out a easier way to do it that isn't lifting the entire car.
Thanks!
shogun32
Northern VA
roll it onto rear ramps, use a bottle pump. OP Mustang's kit comes with all the fixings.
