Welcome to the forum.I have a 2016 Mustang GT PP Edition manual and I want to know if this will require additional cooling since it does have the track pack and a larger radiator from the factory
GT Performance Package includes unique front air splitter; strut-tower brace; larger radiator; upsized rear sway bar; heavy-duty front springs; unique chassis tuning; K-member brace; BremboTM 6-piston front calipers; 19" x 9" front and 19" x 9.5" rear Ebony Black-painted aluminum wheels with 255/40R19 front and 275/40R19 rear summer-only tires2; unique electric power-assisted steering, ABS and electronic stability control tuning; Engine Turn aluminum dash panel; Gauge Pack (oil pressure and vacuum); spoiler delete; and 3.73:1 gear ratio with TORSEN® helical gear differential (n/a with 18" wheels, automatic transmission, Black Accent Package, Interior & Wheel Package, or spare wheel and tire)
TRACK STAR.
While developing the GT Performance Package for Mustang GT, engineers used the previous generation’s Boss® 302 model as their performance benchmark – this race-ready machine is even faster around the track.
Getting it done starts with the underpinnings. The package gives you a strut-tower brace, a K-brace, heavy-duty front springs, an upsized rear sway bar, a larger radiator, a 3.73 TORSEN® rear axle and more.
Cooling for what? Driving to the store to get cupcakes or a 12 hour endurance race in Arizona?I have a 2016 Mustang GT PP Edition manual and I want to know if this will require additional cooling since it does have the track pack and a larger radiator from the factory
The larger radiator yes, but no additional oil cooling. All GTs (regardless of PP or not) come with the same water to oil cooler.The Performance Pack comes with an additional oil cooler and larger radiator for your year, as far as I'm aware.
Sharing info you're not right on. Why even reply?Require additional cooling for what? The Performance Pack comes with an additional oil cooler and larger radiator for your year, as far as I'm aware.
Sharing how much of a dickhead you are, I see. Why even reply? I'm pretty sure the point of my reply was to ask OP what he meant and what he wanted help with, not to provide factually correct information about a year I don't own to satisfy you. Hence the "As far as I'm aware" at the end, because I wasn't sure.Sharing info you're not right on. Why even reply?
You've never seen me drive to the store for cupcakes ... no difference.Cooling for what? Driving to the store to get cupcakes or a 12 hour endurance race in Arizona?
How are you gonna use the car? Just normally on the street?I'm sorry I forgot to add that I was considering super charging it To 750 horsepower.
You don't need a diff or trans cooler for street driving, even with that power. Hell, someone can correct me if I'm wrong but even the factory PP radiator will be fine, you're in PA (as am I) which isn't an extreme hot climate.
It's the Edlebrock stage 1 Kit with the new dual pass intercooler. 740hp+You don't need a diff or trans cooler for street driving, even with that power. Hell, someone can correct me if I'm wrong but even the factory PP radiator will be fine, you're in PA (as am I) which isn't an extreme hot climate.
Worry more about whatever intercooler setup you'll be using for your power adder.
You'll be fine, slap it on and have fun.It's the Edlebrock stage 1 Kit with the new dual pass intercooler. 740hp+
