montreal ponies
- Jan 7, 2014
- Montreal, Canada
- Dan
- ‘17 Ruby red GT350
Thanks for chiming in Keith, looking forward to see what SA will come up with.Guys,
Sorry for not checking in on this sooner! This was developed as an auxiliary cooling component to an entire system. This just came out first. Indeed, on a very hot Vegas summer track day, this alone will postpone the time it takes for limp to kick in on 2015/16 tech cars. However, its not a cure on the hot days or very aggressive sessions. On the street and light track time, this is a very thoughtful, valued orientated setup. Test numbers are pretty vanilla without context so if I told you aluminum surface temp on tranny casing was reduced by almost 50*, I'm not sure that would turn anyone on? Let me know if there's a specific static figure you're after and I'll do my best to provide.
Couple other things that Tim hasn't given away...
1) For the intent observers of the photos, yes another system is being finalized and close to release. Its an active system with thermostatic control and manual override switch, in its current configuration. Stay tuned as this takes a lot of test time and validation prior to release
2)This scoop was meant to be modular, which means we will be releasing a version that is meant for GT/Ecoboost.
3) Please don't wrap your catalytic converters. You will not enjoy the end result or complete denial of Ford warranty coverage, either
Thanks, as always!!!
