2015-2016 Tech Pack and Base GT350 Cooler Solution Discussion
VOODOO 6G
Ohio
Eric
2016 Shelby GT350
Just got off the phone with my dealership and got the part# for the transmission they are sending to put in my car. It's the same part # Epiphany has on the transmission he ordered. FR3Z 7003-E. Now I just have to buy the rest of the cooler kit. So, good news after all.
Wow, that is awesome.... I think I heard a grinding sound in mine last weekend..... What dealer are you going through again.....
Caballus
Over Yonder
GT350
As ironic as it sounds, congrats on a transmission failure, or less ironically, the solution for a transmission failure. That is great news!!
stshoo
SW Florida
Scott
2016 Avalanche w/Black Stripe and roof, tech pack
So this may be a dumb question but, if they are replacing with the 'good' transmission and it's under warranty, is there an adaptor kit on it for tech pack cars? I doubt Ford will pay for the rest of the parts to put the coolers in? Will it just have a loop hose from the inlet and out let and the owner can elect to put the rest of the system in or?
shelby24
New Haven
2016 Shelby GT350
I had what was probably one of the first TR3160's available as soon as Ford Parts and Service was able to sell them.
Mind you it was more than $4,000 and that was just over dealer cost from Tousley (and had no internal pump). Core charge additional. Today I got a message from Mike at Buyfordracing that he has the just released Ford Racing TR3160 transmissions (with coolant pump) in stock. Retail on these is $4,800.
https://performanceparts.ford.com/part/M-7000-M8S
He is selling them for $2,700, a price he can't advertise. If you can find a better deal, jump on it because that is very reasonable.
Why did u buy the trans if it had no internal pump?
Epiphany
Global
I like to disassemble things.
Transmissions with the pump were not yet available. I used the transmission to fabricate a stand and the gentlemen that took possession of the transmission after me used it to make the best shifter a Mustang has ever seen.
:ninja:
shelby24
New Haven
2016 Shelby GT350
:ninja:
How do you get in touch with Mike to get that price $2700 for trans?
lemers
Globetrotter
Carlisle, PA
2016 GT350
150 lbs is too much for an APO delivery. :(
Epiphany
Global
Tank
9/11 - Never Forget
Above the Notches
G0853
This should work with the FP kit designed to work with a TR3160 with a factory internal pump, yes. This transmission will have the stock fill/drain/ port plugs.
Just for clarification, port plugs for the cooler lines? Also, whatcha gonna do with your new transmission stand? :)
Thanks [MENTION=19066]Epiphany[/MENTION] :cheers:
Epiphany
Global
The stand shares work with a number of other stands I fabricated. They are used to aid in design/development as well as show duty at events such as Mustangweek.
Regarding plugs, I was referring to the threaded pipe plugs in response to an earlier question. The ports for the cooler lines may or may not have a plastic/rubber plug to keep the orifices clean on the Track Pack transmission prior to installation.
Tank
9/11 - Never Forget
Above the Notches
G0853
Cool stuff Epiphany! Thanks for the pics and info!
Minn19
Minnesota
Jason
19 ZL1 1LE, 19 F150, 19 SB S5
Has anyone considered boycotting the pending cooler fix and/or transmission with internal pump in an attempt to leverage a more acceptable resolution?
I'm not sure what that would do. We are not currently in a position to leverage anything because they hold all of the cards/power.
I'm probably not going to get either of their solutions (not because of a snub against Ford or anything). If I'm not going to have a warranty on my transmission either way, I'm going to most likely bring my car to a local Mustang tuning shop. They get very good reviews and probably care much more about their reputation than any regular Ford dealer does.
shelby24
New Haven
2016 Shelby GT350
Unfortunately I don't think that we have the numbers to put a scare into ford.
If there were thousands of people maybe but I don't even know if there is a 100 people that would like to occasionally go to the track. What everyone that does not have a trans/diff cooler should realize that 240 degrees plus heat can not be good for there transmissions. Just my 2 cents
