2000 HP DSS Axles
Leonidas514
Oviedo, FL
Chad
2015 GT
Guys - just curious if any of you have any knowledge. I pulled my DSS axles today and on one of them the spline just spins almost like when I whacked it to get it out, it popped something inside. I was going to sell them since the last time out the worked fine. It's the spline nearest the spindle. It's recessed about an inch and just free spins.
sell them… and if you're going to put forth the effort to swap out half shafts for something superior, get GForce half shafts...
When you have time, read this:
http://www.mustangandfords.com/how-...les-fragility-to-rest-with-gforce-engineering
And this (scroll down to the half shaft section):
http://terminator-cobra.com/suspension.htm#Half-Shafts
and here’s the offerings from G-Force for the S550:
https://gforce1320.com/product-category/mustang/
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
I've got the G force on order along with the 9 inch conversion. I've for the Strange chunk sitting in the garage, that's why I pulled those axles. I'll read through your links and thanks as usual!
You’re on the right track then w/GForce! :clap:🍺
beefcake
Bethel
2018 Ford Mustang
both companies do a great job, we stock and sell a ton of both.
we have customers that break both, even had a customer brake a 9" dss axle.
it happens. and it happens with both of them.
I had 3 years of passes with 0 failure up to the 1300 wheel range and probably 15 passes with 0 issue on the dss, after breaking the factory diff. had dss build us a 9"
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
Wasn't dogging either company. Not sure how I broke it by removing it from the car. They worked great on the car with over 1000hp.
beefcake
Bethel
2018 Ford Mustang
i know.
just whenever someone has an issue with dss, everyone chimes in that gforce is the best
whenever someone has an issue with gforce, everyone chimes in that dss is the best.
so i always chime in on both lol
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
i know.
Makes sense. The DSS worked great.
