19x10.5 +30 squared
Nick610s
nor cal
2015 Comp Orange GT
Is this setup doable on our car? Found a wheel I like. And that's the highest offset it comes in. Looks like front should stick out a little bit. Rear I'm not so sure. Searched for the answer but no one running this yet. Or hasn't tried.
Nick610s
nor cal
2015 Comp Orange GT
Yeah those wheels def tuck in at +48 in the rear. I have a few machinist friends that could mill 5mm off the inside to pull it in a touch.i figure +35 all around would be ideal for that width to make it squared. I wish we could stick wider tires in the front without issues. And run a bigger wheel. I am waiting for the konis to come out so I can get some ground control coilover sleeves and springs. 285/295 for daily/once in a while track car would be ok.
BigEasyGT
New Orleans
2015 GT PP
I've got 20x10.5 +30 wheels with 275/35 tires on the way to my house now. I'm lowered on sportlines and it should fit fine. I'll post pics once they come in.
Nick610s
nor cal
2015 Comp Orange GT
hmmmmm usually on a 19x10.5 we would recommend somewhere in the 35et -45et range.. 35et will already be fender edge border .... idk.... lets see what it looks like guys.
Well then as I stated before, if I mill 5mm off I should get a +35 offset effectively bringing the wheel more flush to the top of the fender. Like I said I will have adjustable height and camber pieces once they get to production.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
It is doable the front will poke and the rear will poke a tad but with say a 275/35/19 tire it can work.
Nick610s
nor cal
2015 Comp Orange GT
Must go wider! I'm hell bent on 285+! I'm a handling person but I don't want to stay 18" wheels. And don't have forgestar or custom wheel money and there are no other thick 6 spoke wheels available with the exact offset unless I order volk te37's. And again don't have 4K to drop. Lol.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Youll need camber to make it work then bro, What about the Project 6GR wheels then
19x10 ET 35 rock the 285 itll be flush and you wont have headaches.
Nick610s
nor cal
2015 Comp Orange GT
I planned on some camber with some max Motorsports or similar camber plates. But those 6gr wheels look cool. Send me a quote what I'd be looking at for a set.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
You got it bro.
