170 degree thermometer with Lund Tune
rozay
South Florida, Broward
2015 PQ 5.0 MT
Spoke to Greg from Lund and said that no updates were needed for the thermostat
CEHollier
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
So from what I am gathering some people are using a 180 degree thermostat with their Lund tune. Others are using the 170 degree thermostat with basically the same tune mod for mod. If you check the 170 degree thermostat ordering the tune it changes nothing. Am I understanding this correctly? The 170 degree thermostat just helps prevent detonation on Lund's standard tune.
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
Basically yes, you can either use the stock one or get the 170. Tune doesn't change, and you don't have to select either as an option when ordering the tune. My message as follows:
Ryan Jones
Ryan Jones
Sep 9, 12:01 AM
Hello, I just ordered a Reische Performance FORD-50 170° Performance Thermostat, and was wondering if I would need an update to my tune for it. Thank you.
John Nardi
John Nardi (Lund Racing Support)
Sep 9, 7:47 AM
No tune adjustment needed Ryan. You are set! It is a wise move to do the 170 tstat. Tune is already setup to kick fans on earlier.
John Nardi
www.LundRacing.com
CEHollier
CEHollier
Prairieville, La.
Charles
Ryan Jones
Ryan Jones
Sep 9, 12:01 AM
John Nardi
Sep 9, 7:47 AM
John Nardi
www.LundRacing.com
Ryan - Thank you for the confirmation.
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
What exactly is the Lund 93 tune adjust on the car with no mods at all?
CEHollier
CEHollier
Prairieville, La.
Charles
I am no expert by any stretch but from what I understand it adjusts shift points, timing, and air/fuel flow. Just installed a Lund tune today with a JLT CAI. The Corsa exhaust will get here in a week or so. So far with stock exhaust I am very happy with the drivability and performance of the tune. I would recommend it. I do feel a difference in low end torque/responsiveness. And at WOT I feel improvement too.
r1lovin
colorado
2015 Gt
What about cold weather with the 170* thermostat? Any isdues?
Excelerater
Memphis TN
2015 GT
Thermostat being lower ,if the fans are also at lower temps settings you have a cooler running engine which is more HP BUT can lead to carbon build up and a few other issues in a daily driver situation .
How is it different on a Coyote ?
Schu
Las Vegas, NV
S550GTPP
Is anyone running a Lund tune with the factory 180 degree thermostat on a 2015 GT? Is anyone running the optional 170 degree thermostat. I would appreciate any feedback from people who are doing it.
I am...
Lund+180Âş=fans always on once up to temp
Lund+170Âş=no fans on.
CEHollier
CEHollier
Prairieville, La.
Charles
I am...
That's what I have read here and on other forums. Just put a JLT CAI with a Lune tune on my GT. I have the 170 thermostat and will install soon.
beefcake
Bethel
2018 Ford Mustang
you can run the tune either way, lund turns the fans on sooner, no matter thermostat or not
they can be turned on later if you prefer, however you want it, several threads on this
we have the 170s in stock.
as far as cold, the 170 is the perfect temp tstat to keep you where you want to be
I think when you start getting below that like the 160's, you could run into issues
http://teambeefcakeracing.com/rpford50.html
09jsw
East coast
2015 Guard PP GT
I don't think this is a real issue with the 170 stat. Stock is 177 deg so hardly a dif but it's enough with the tune to make a dif.
